08Aug: Spectral sweep through the Ca K line
- p_zetner
Hi Everyone.
Here is an animated spectral sweep through the Ca K line from data taken during my 08Aug imaging session. The wavelength offsets (in milliAngstroms) are marked in the upper left hand corner of each frame. The frame rate is rather slow this time. I used one second per frame (36 frames) for this animation. The entire sweep covers about 1.7 Angstroms. (You can see why a Lunt CaK filter bandpass of 2.2A will fail to reveal filaments!)
Cheers, Peter.
Cheers, Peter.
Re: 08Aug: Spectral sweep through the Ca K line
Hi Peter,
very instructing and useful for judging if a CaK-filter is on band or not, thanks for posting!
Frank
Frank
Stunning, however the Lunt is 2.4A so it is even worse than you state, the old PST was 2.2A. I wish there was a filter which was tighter. I think Mark's double stack CaK PST filter is the best I have seen.
This is great for reference material
That's a stunner Peter! I wish my CaK were that good!
Peter,
Well done mate!
What bandwidth were you using??
Well done mate!
Fabulous sequence, Peter. Very enlightening!
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
NEQ6 Pro-mount
- p_zetner
Thanks for all your comments, Everyone.
Ken: I haven't bench tested this lately but can get a rough estimation from my H alpha results of this August. If I compare the fwhm of a measured spectral line in my instrument with a spectral linewidth of the same line in the BASS2000 spectrum, I get an instrumental bandpass of ~ 0.18 Angstrom (fwhm) near H alpha for my spectrometer in the present configuration (25 micron slit, 500mmf collimator, 2400 l/mm grating, 300mmf camera lens).
Here is a comparison plot of a measured spectrum taken on August 8 and the BASS2000 spectrum.
In this magnified view, I'm comparing the widths of a relatively isolated feature. The BASS2000 spectrum claims a resolution of 0.01 Angstrom and I'm assuming the relation: BASS2000_fwhm^2 + Instrumental_fwhm^2 = Measured_fwhm^2 , which is strict for Gaussian profiles. From the fwhm values quoted on the last plot, the Instrumental_fwhm can be calculated to be ~0.18 Angstroms. This seems to be pretty reasonable when you observe how the images change over the course of the spectral sweep.
It's much more difficult to do this type of comparison in the uv because of the congested nature of the spectrum. Here's an example.
Cheers, Peter.
Cheers, Peter.
Peter,
As you appreciate it's always difficult to estimate the resolution from spectra comparison. A spectral reference lamp is the preferred method.
Notwithstanding, I think you're pretty close in your estimates....
I ran your spectroheliograph through the SimSpec_SHG for comparison......
Hi Peter,p_zetner wrote: ↑Tue Aug 28, 2018 4:38 pmHi Everyone.
Cheers, Peter.
Missed this topic, unfortunately. Reading it now. Thanks a lot for such a nice animation - very illustrative!
OK about the band pass which allows to image filaments. What must be the FWHM to see them with confidence?
- p_zetner
Ken: Thanks for running the calculation. It seems to be in the ball park, although, I guess, it is a best estimate of resolution as, for example, optical aberrations aren't considered. It's pure laziness that I haven't made a bench test of the resolution recently. I'll do this in the near future.
Valery: To roughly answer your question, I can average together some number of frames around line centre to model the action of a filter of given fwhm bandpass. Ideally, this would be a weighted average to simulate, say, a Gaussian bandpass. I'll work on this. Straightforward averaging of frames is easy in ImageJ and, I suppose, would give a rough answer to your question but I have to figure out how to accomplish the weighted averaging for a more refined answer.
Peter
Peter
Hi Peter,
This is great !!
Could you display the individual frames in a single large image, just like you did for Ha ?
This is great !!
http://www.astroplanetes.com/
It looks like that the filaments are best visible in the range of plus / minus 0.080 A.
This means that a filter should have a FWHM < 0.16 A to show any filaments.
very cool to see sweep
- p_zetner
Thanks, John.
As you can imagine, these animations require a lot of work (40 spectroheliograms in this case) but I enjoy the end result.
Peter
Peter
