Orionids by radio detection-UPDATED
Has thanked: 1210 times
Been thanked: 1027 times
Post by Carbon60 » Thu Oct 22, 2020 6:49 pm
Radio detected Orionids (Halley's comet debris) which peaked 20/21st October, though detections began sooner (looks like around 14th).
Draconids_Orionids_October 2020.jpg (155.4 KiB) Viewed 350 times
Not as impressive as the Perseids, but detectable nevertheless.
Thanks for looking.
rsfoto
Has thanked: 1925 times
Been thanked: 1419 times
Re: Orionids by radio detection
Post by rsfoto » Thu Oct 22, 2020 8:35 pm
Hi Stu,
Very good. I got 20 times the maximum impacts you have recorded. I am still working out what is going on. ¿?
Post by Carbon60 » Thu Oct 22, 2020 9:03 pm
Hi Rainer,
It depends how the count rates are calculated, as the apparent hourly rate can vary significantly depending on the time period over which the counts are collected. Can you plot the growth of the cumulative count over a 24 hour period, or send me your data for October 20th and then I can do a direct comparison with mine?
Has thanked: 2910 times
Been thanked: 1099 times
Post by Montana » Fri Oct 23, 2020 8:39 am
That's great Stuart, however these peaks are only marginal compared to baseline rates which surprises me, however, that could be normal and this is why folks get disappointed when nothing happens when they watch the heavens for 30 minutes ;)
:bow
rsfoto
Post by rsfoto » Fri Oct 23, 2020 11:06 pm
Hi Rainer,
Hi Stu,
You can download it from here
https://www.rmob.org/livedata/live_data ... 20rmob.TXT
Rainer
Wyvern
Has thanked: 13 times
Been thanked: 14 times
Post by Wyvern » Sat Oct 24, 2020 2:34 pm
Dear all,
My Orionid results over the past few days for comparison.
Moxon ariel working GRAVES with SDR# displaying "pings" on the computer monitor. The display is automatically screengrabbed while the detection system is running and counts are done manually and turned into the graphical displays for interpretation.
Regards to all,
Les
Orionids Numbers.jpg (40.92 KiB) Viewed 321 times
Orionids Bar.jpg (80.65 KiB) Viewed 321 times
Orionids Line.jpg (90.99 KiB) Viewed 321 times
8" SkyWatcher reflector on HEQ6. 10" Meade S/C & 16" Meade reflector awaiting obsy "planning permission"!
Coronado PST & Lunt Herschel wedge for 120mm SkyWatcher refractor on EQ4.
Graves meteor detection system.
Canon 1100d & ZWO ASI120mc for imaging.
Photoshop skills questionable.
Post by Montana » Sun Oct 25, 2020 12:26 pm
Beautifully presented Les, great results!!
:bow
Post by Carbon60 » Sun Oct 25, 2020 4:07 pm
Nice one, Les.
Re: Orionids by radio detection-UPDATED
Post by Carbon60 » Tue Oct 27, 2020 3:11 pm
Some updated radio detection data.
Looks like another bit of a spike in the Orionid shower on the 24th, maybe....
Draconids_Orionids_October 2020.jpg (181.08 KiB) Viewed 286 times
Thanks for looking.
rsfoto
Post by rsfoto » Tue Oct 27, 2020 5:48 pm
Hi Stu,
My former statistics lack of accuracy. Changed my setup. Took out the Low Noise Wideband amplifier and installed a home made Helical Bandpass filter for 174.31 MHz.
My friends set up and mine are quite sunchronized in catdching metoers but still differences.
He is 70 meters lower in height then I am.
Below an image of the Helical Bandpass filter I built for gettting rid pf the RFI [Radio Frequency Interference] downtown. Makes the noise level much flatter and the SNR comes out better. All this thanks to some HAM Radio amateurs in the Ham-Antennas group.io.
My friend did no get more then maybe 5 echoes a day and now he gets nice echoes during24 hours. Similar to me.
His statistics, before and after
Below the Helical Bandpass filter in open and closed conditions while I was tuning it with a Nano VNA [Virtual Network Analyzer]
Post by Carbon60 » Tue Oct 27, 2020 6:48 pm
Excellent, Rainer. That’s an impressive build. It will be interesting to see how the data stack up over the next couple of months with the Leonids and Geminids coming up.
I’ve noticed that nearly everyone gets different results in terms of numbers and timings of peak showers. So much depends on the specifics of each location and setup, it seems.
Your setup has come along in leaps and bounds, as we say, so really nice work, Rainer.
rsfoto
Post by rsfoto » Wed Oct 28, 2020 2:20 am
Hi Stu,
Thanks. It is already very interesting as my friend Downtown has the same set up as I have and the capture is already different and we are only 4.5 km apart.
Same Antennas, same Bandpass filter both built by me, Same RTL-SDR. Same adjustments in SDR# and Spectrum Lab ... :o :o :o
There is a so called eventlogYYYMMDD.txt file with some data. We will compare that data to see better what or how all this behaves.
Me on the left and he on the right
Has thanked: 2907 times
Been thanked: 1175 times
Post by marktownley » Thu Oct 29, 2020 2:27 pm
Cool thread everyone!
