Hello Everyone.
More spectroheliograph stuff!
First some spectra near H-alpha and CaK.
H-alpha Spectrum:
CaK Spectrum:
Comparison is made with the BASS2000 solar spectra. Agreement is generally pretty good with some discrepancies - like additional observed lines!
Here is an image (not great) taken at H alpha line centre.
H alpha image
Lots of room for improvement here!
I re-configured my Aug 25 CaK images for display as a collage:
CaK Spectral Series
CaK Spectral Series (Full Size)
Once again, you can clearly see a filament present in frames 5 - 7 (South region).
Each frame represents an image constructed from a 1px spectral slice taken in the spectral location identified in the following graph.
Here is a spectrum showing the difference between CaK absorption in the presence and absence of plage:
The classic bright peaks in K2r and K2v are visible!
Quite a few things left to do to improve image quality. For one thing, I haven't completely eliminated the problem of the curvature of the spectral lines. Consequently, feature contrast in the polar regions is always worse than in the equatorial regions of the image. I've used the General Quadrilateral Transform filter in VirtualDub but some of the problem persists and is a killer in H alpha where the line is relatively narrow (compared to CaK). I'm continuing to work on it!
Peter.
Spectroheliograph: Images and Spectra
- Has thanked: 20442 times
- Been thanked: 10247 times
Re: Spectroheliograph: Images and Spectra
I'm liking this Peter, it helps me develop my understanding with CaK as to how it all works and then can use the information to tweak my own approaches to both filter and equipment design, and then also processing. Thank you
Hi Peter
thank you for that interesting stuf
- Been thanked: 8791 times
Absolutely stunning work : : : this is fabulous information when we have so little info about the CaK region. Many thanks and great work
Peter.
Hello!
Really nice work!
Can you please show us an image of the problem?
Greetings from Poland
Alex
- Has thanked: 8418 times
- Been thanked: 8163 times
Great work Peter.
Very interesting data.
