20131115 Spectrohelioscope First Light~!
- Has thanked: 8 times
- Been thanked: 17 times
Captured the video before going to work this morning.
I can see tiny prominence in the raw spectrum!
That was so exciting~! :woohoo: :woohoo: :woohoo: :woohoo:
- Has thanked: 173 times
- Been thanked: 615 times
Re: 20131115 Spectrohelioscope First Light~!
Well done!
A small step along the way...but going in the right direction.
Look forward to seeing your final images.
- Has thanked: 20424 times
- Been thanked: 10243 times
Good stuff there Wah!
- Has thanked: 17667 times
- Been thanked: 8787 times
Excellent work :
Can you point out the prominence
please could I have a beginners guide
Am I looking at the vertical or horizontal lines? how do you know it is a prominence and not an absorption line? I'm not really sure what I am looking at.
Oh I see it's lovely you have to bear with me
Good stuff! I'm like Alexandra here, all the spectroscopy is completely new to me...
The dark absorption line of Ha can show both proms (at the solar edge), bright areas of plage/ sunspots and darker areas of filaments/ sunspots.
As the slit in the spectrohelioscope (SHS) "scans" across the solar disk each CCD frame contains an Ha line with this data. Think of it like an old TV with 500 lines which make up the final image...
Similarly if the column containing the Ha data is isolated and separated from each frame then stacked one next to each other a full disk image showing the usual surfaces features can be obtained.
The software used is getting better and better. Give it a couple of more years and I'm sure SHS's will be producing images (at any wavelength!) of great detail and resolution.
Very impressive result Wah!
I understand now
and these images are terrific Wah : : :
Hi Wah
congratulations on the first light. A great job
