20131207 Ha, Ca, Hb
- Has thanked: 174 times
- Been thanked: 619 times
Re: 20131207 Ha, Ca, Hb
Very good!
I'm sure they will improve even more when you get the final optics/slit.
Looking good Wah I am enjoying watching your progression with this apparartus.
- Has thanked: 20819 times
- Been thanked: 10489 times
Brilliant! Lots of fun!
- DSobserver
- Been thanked: 19 times
- Has thanked: 8 times
- Been thanked: 17 times
This is the program I wrote.
It does not support mono8 encoding avi directly from SharpCap.
It may crash when processing high resolution avi.
It does not support bent spectral lines.
It can save result as 24bpp png only.
1. Select avi file that previously cropped by VirtualDub. (You can drag & drop the file to the address bar)
2. Drag the track bar to view frames
3. Click "First" or "Last" button to control the range to be merged
4. Click on the frame to select spectral line for merging.
5. "Line Width" is for changing the "bandwidth"
6. "Rotation" can help to rotate the spectral lines to better orientation
7. "Frame divide", frames to skip after each merging frame (don't know how to say, just try it)
8. "Horizontal mode" for avi that capture the spectral line horizontally
9. Click "Merge!" to get the result. Merged image will be saved automatically.
Attached files SpecLineMerge.zip (240.7 KB)
Hi Wah
that program looks good, congratulations on writing it
- Been thanked: 8906 times
Excellent work Wah, I'm thoroughly enjoying watching everyones progress
- sullij1
Way to go Wah! Even though I won't use the program, thanks for maintaining the spirit of the forum and sharing. Thats big of ya mate!
Look Up!
- DSobserver
thanx wah!
But I couldn't run it, apparently some files are missing.... :huh:
I just rebuilt the program to .NET 2.0 based, hope you don't need to install a new one.
BTW, I have received my 5 lucky lenses yesterday.
I have found that all the 5 lenses are better than the original one!
I have replaced the lens and pray for the image quality can be improved :whistle: :whistle: :whistle:
Attached files SpecLineMerge_2013-12-09.zip (284.4 KB)
- DSobserver
great your soft works perfectly and it's really easy to use!
Now I only need to fine tune the optic side of the SHS du to some focus issues.... :sick:
