How to find interesting solar spectral lines?
- Has thanked: 8 times
- Been thanked: 17 times
There are thousands of spectral lines in the solar spectrum, how do you guys find those interesting ones? I've been struggling searching from google even just for H-beta…
Re: How to find interesting solar spectral lines?
Two books I recommend as reference:
"Astrophysics of the Sun" by Harold Zirin, and "Guide to the Sun" by Kenneth J H Phillips.
The most interesting lines seem to be the Chromosphere Ha, CaK (k1-k2-k3)then there's the higher temperature MgIIk line (k1-k2-k3) also the HeI D3, NaI D, and MgIb
The red/blue "wings" of Ha are at a lower surface height (300km) than the core (1500Km) so have the potential to give different data.
Is there any textbook spectrum can point out where these lines are?
I have difficulty to find them out from the realtime images of the camera, especially the camera is a B/W one.
Use the Liege Solar Spectral Atlas to find where you are and identify all the solar lines (!!)
http://fermi.jhuapl.edu/liege/s02_0000.html
The BASS has a printout of the whole solar spectrum, annotated, this also helps...
http://bass2000.obspm.fr/solar_spect.php?step=1
I just checked my spectrum near CaK, the resolution is better than Level 4 and worse than Level 5
http://fermi.jhuapl.edu/liege/s05_0003.html
Just found an informative website, don't know if you know it before:
http://www.nist.gov/pml/data/handbook/index.cfm
Hi Wah
thanks for the interesting links
For standard gas discharge spectra, this is good:
http://astro.u-strasbg.fr/~koppen/discharge/
