Spectroscope built by my niece
Has thanked: 17925 times
Been thanked: 8891 times
My niece and nephew came round for tea last night and my niece brought round her spectroscope she has built to show me. She wanted me to share it with you all so I took some photographs for you to see. She was given a grating by a chap at the local astro society so she designed how she wanted to fix it to her telescope
Then she built it out of bits of wood
and managed to take a spectrum of some reflected sunlight from the moon with her DSLR
I am very proud of her achievement.
The only problem she was saying was that the lines are not very focused and I said her slit was too wide. The problem is that she said if the slit was narrower then the amount of light coming through is too dim to take a photograph. Any suggestions to get over this would be welcome?
Kind regards
Alexandra and Emily
Has thanked: 20738 times
Been thanked: 10439 times
Re: Spectroscope built by my niece
Woohoo! That's great stuff Alexandra and Emily. I'm not sure what to suggest to answer your question, but i'm sure there are people here who do know and will be able to help.
highfnum
Has thanked: 57 times
Been thanked: 1193 times
Post by highfnum »
do I see absorption lines in there?
cool
Been thanked: 1 time
Post by swisswalter »
Hi Emily
congratulations. What a mod. Me too I can see absorption lines.
robert
Has thanked: 4 times
Been thanked: 1275 times
Post by robert »
cool
:thumbsup:
Robert
Has thanked: 8523 times
Been thanked: 8253 times
Post by Carbon60 »
Nice work, Emily.
I'm sure someone from this forum will be able to advise.
Looking good though.
p_zetner
Has thanked: 166 times
Been thanked: 719 times
Post by p_zetner »
Hi Alexandra and Emily.
Nice job!
I do have a couple of suggestions, though. It looks to me like the eyepiece is backwards. The goal is to put the slit at the eyepiece focus (not the observing end).
Also, you don't have a collimating lens in this arrangement (between slit and grating) so, a longer focal length eyepiece would give a better approximation to the required parallel beam at the grating. At the moment, because of the short eyepiece focal length, you're probably throwing much of the incident light around the grating (severe vignetting). Also, as an added benefit, a longer focal length eyepiece would have larger aperture lenses and collect more intensity.
If you wanted to do a bit of a re-design, a collimating lens would probably improve your results significantly.
Peter.
Has thanked: 174 times
Been thanked: 618 times
Post by Merlin66 »
Well done to your niece for attempting this project!!
As Peter says, the slit (there seems to be a series of holes??- maybe just the image?)should be as narrow as possible and positioned at the focus of a very low powered eyepiece - an achromat (surplus shed?) would be better.
Then the parallel, collimated beam is directed to the grating and the diffracted spectrum to the camera lens.
The grating (if blazed, for maximum efficiency)will be seen to produce a series of spectra on both sides of the "normal" axis - look for the brightest (1st Order) and direct this to the camera.
Onwards and upwards.
Thanks guys :thanx:
In lay mans speak do you mean that the slit needs to be before the eyepiece? if that is the case does that mean you have to try and make a round one and slot it in the hole before the eyepiece goes into the telescope?
Also, what do you use for a collimating lens? and where does that go?
Many thanks
Derek Klepp
Been thanked: 171 times
Post by Derek Klepp »
This is really great stuff Alexandra and I would think one of the reasons Stephen created this forum, to get younger people involved in science.And at the same time have the benefits of those such as Ken and Peter to help out.
Post by Merlin66 »
Alexandra,
The slit should be positioned at the focus of the telescope. A lens (the collimator)or very low power eyepiece is then focused on this slit.
If you use a collimating lens, this can be a simple x0.5 eyepiece reducer (like they use for imaging a webcam) These small (28mm diameter) lenses are usually about 80mm focal length.
The emerging beam from this lens is parallel and should be directed at the grating. The spectrum formed by reflection from the grating is then imaged with a camera lens.
That's the basics.
The attached sketch should help. I obviously could go into much more detail. let me know if I can assist further.
Thanks Ken :)
I'll chat to her on Christmas day and show her all the info :thanx:
