I have found interesting bright line of He-D3 when the slit is on the edge of the sun.
I am not able to get obvious darkening active regions on the solar suface, but still be able to process out the brightest proms on the left.
I think it is because my spectroscope dispersion is still not good enough for this line.
The Ca-H is worse than before after tuning the spectroscope last night.
But the H-a is better this time
And the H-b is the best for today
20131226 X'mas He-D3, Ca-H, H-a, H-b
- Has thanked: 20962 times
- Been thanked: 10593 times
Re: 20131226 X'mas He-D3
I'm impressed Wah!
Hi Wah
great results
great results
- Has thanked: 57 times
- Been thanked: 1213 times
- Has thanked: 18105 times
- Been thanked: 8942 times
- Has thanked: 65 times
- Been thanked: 4462 times
Re: 20131226 X'mas He-D3, Ca-H, H-a, H-b
Excellent results and a lot of hard work...well done :
