There is so much tiny dust on the slit of my spectroscope, how can I clean it without adding more dust on it?
I've tried using a tooth pick to clean it, but usually don't success...
How to remove dust from the optical slit of spectroscope?
- Has thanked: 174 times
- Been thanked: 619 times
Re: How to remove dust from the optical slit of spectroscope?
Wah,
On my Surplus Shed adjustable slits I find a blast of compressed air generally works. Then I use a wooden toothpick in a wide slit gap to "wipe" the edges, generally works very well.
(The new multi-slit reflective plates we now use are a dream...no gaps to collect dust and the actual slit is protected behind glass.)
Wah,
The multi slit plate (9 slits 20-100micron and 3 pinholes 20-100micron) I designed it for the new Spectra-L200 spectroscope. There's details over on the astronomical spectroscopy group.
I have a few left, $65 delivered...drop me an email.
- Has thanked: 8 times
- Been thanked: 17 times
I finally have found the topic:
http://groups.yahoo.com/neo/groups/astr ... opics/6703
It seems the slits are quite short, it requires to scan the sun twice for a full disk if the telescope has focal length longer than 600mm, right?
Does a glass slit become very hot after the focused solar image shining on it?
BTW, it there any topic about how wide should a slit be?
Wah,
Yes....
It was designed for spectroscopy not specifically for a spectrohelioscope...
I've used in in my MG80 spectroscope for solar spectrum recording with no effects...it reflects 99% of the light and heat.
You can calculate the optimum slit gap from the spreadsheet SimSpecV4 (in the astronomical spectroscopy group files area)- this looks at your focal length, grating and camera pixel size...the smallest projected slit (on the CCD) would be between 2 and 3 times the pixel size (Nyquist sampling) i.e. a 5 micron pixel = 10-15micron projected slit. If you have a 500 mm collimator and a 200mm imaging lens then the actual slit gap could be 500/200 * 10 = 25micron.
Yes....
Dear Merlin,
Can this product be used on a SHS?
http://catalogue.ovio-optics.com/index. ... &Itemid=10
It seems to be longer...
Wah!
Wah!
Wah!,
Yes. I used these before custom designing the multi-slit plate for the spectroscope.
Limited line widths....
That's exactly the one I started with...infact I may still have one.
Drop me an email and I'll check my "box" for you...
They are not cheap.
They are not cheap.
