PST Stage 1 + AR152, AR102, 72ED etc. next steps ...
- solarchatted
- Has thanked: 12 times
- Been thanked: 10 times
ADDITION - I failed to mention I will use the Altair 178M camera I am already using with PST
Hi again!
Sorry for being 'slow' and possibly thick.
My plan:
1.
I think, first thing is to get the 2" adaptor for PST - so I am ready to play with Stage 1 [I guess it is called?]
2.
Then get a 100mm ERF [when i can afford it] and make an adaptor/cap myself - I am good at it [or so I believe!] and fit 3x Nylon screws on it to hold it in place, behind the edge for the retractor's shield.
Although I am now thinking I should take the shield off for Solar, so the ERF is next to the glass?
3.
Then fit the 100mm ERF over the AR152 [988mm FL - 152mm Diam - F/6.5] - so it becomes ~F/10
4.
Then eventually also test my AR102SX [459mm FL - F/4.5] and make a 45mm 'card-board' reducer covered in tin-foil 'over the 100mm ERF' and reach F/10 again
5.
For full disk I can use my SW 72ED and simply adapt the 100mm ERF cap over the SW 72ED - maybe just fit longer nylon screws to hold it!
I might have to keep those cream cheese card-board round boxes then (~110mm diam)!!!
6.
or simply get a 63/840 OTA and there is no need to get a ERF (although always best to get one!)
My questions:
a.
What are your 'expert' thoughts above my points above?
b.
Where am I going wrong in terms of 'being able to focus easily'?
c.
Please tell me I am thick, but give us a solution that can account for:
Results [first], Focusing and costs ?
I am no expert and cannot contribute much 'at least at this stage'
Thanks again for taking the trouble to reply.
M
PS I am a kind of practical guy and 'do this and do that' replies are the best to achieve ... at least with my brain ... I usually learn by watching others and as a friend of my late dad used to say: I might be no expert in something and it might take 5x the time an expert takes to do it, but I will blooming do it too! I take this approach too, but do a lot of research first and learn from others than know FAR more than me.
First you learn what I am going to do that, then the how to do that becomes easier knowing what you are doing.
Hi again!
My plan:
1.
2.
3.
4.
5.
6.
My questions:
a.
b.
c.
M
SolarChatted
https://astronomo.space/my-images/the-sun/
https://www.youtube.com/@Astronomo_Space
Solar Gear:
Bresser AR90/900 + PST mod + SW Auto Focuser ...
Sometime I use Explorer Scientific AR152/988 + Used once only... Altair 2" Solar Wedge (very good indeed)
Will try and do it justice when I can with the help of various filters, Baader 1.25" Solar Continuum 10nm is one.
SW 72ED Pro - fixed 'stock faulty' focuser ... 'I think' !
Solar Gear:
- solarchatted
Re: PST Stage 1 + AR152, AR102, 72ED etc. next steps ...
Here a few images taken with PST + 178M.
I t is so difficult to find good weather in Northern England to match my days off work!
SolarChatted
Solar Gear:
Solar Gear:
- solarchatted
This is another telescope I forgot to mention:
https://www.telescopehouse.com/telescop ... embly.html
SolarChatted
Solar Gear:
Solar Gear:
- Has thanked: 20819 times
- Been thanked: 10489 times
HIya, my thoughts...
1 - a necessity!
2 - Yes, for a more secure and easier fit for your ERF use masking tape and wrap around the perimeter of the ERF, make this so it is a push interference fit inside the dew shield.
3 - Yes
4 - Just use the PST native, you're not going to get much more going from 40mm to 45mm aperture to be perfectly honest.
5 - For full disk use the PST, with a 72mm scope your fov that is within the sweetspot is only going to be about a quarter of a disk.
6 - Why? if you have the other scopes already?
a - see above
b - Are you struggling with focus visually or with imaging?
c - cost wise the 90mm bresser is a winner, you could use a sub aperture ERF to conserve funds...
1 - a necessity!
3 - Yes
a - see above
- solarchatted
Thank you very much for taking the time to reply.
It is almost as clear as daylight now and I am guessing I will not need to modify AR152 inward as I might use a smaller ERF [90-100mm] and reach focus?
Sorry for late reply as usual... I thought forum was set to auto-subscribe to get email notifications on my own thread.
OK, time for decisions now.
M
M
SolarChatted
Solar Gear:
Solar Gear:
- solarchatted
Oops!
I just thought about a 63mm or maybe a 80mm ERF used on a Meade SCT 10" Classic [old one].
Using it off-axis with PST ?
I did get decent images in white light years ago and I was only playing with it!
Maybe 63mm too small for a F/10 254mm 2500mm FL ?
SolarChatted
Solar Gear:
Solar Gear:
Personally, I would stick with your refractors for a PST mod. No point using the SCT unless it is full aperture with a full aperture ERF.
- solarchatted
OK, understood.
Just slightly off-topic ...
This morning I 'thought' I had some SUN out and it was out then clouded up by the time I was ready to 'try' a Revelation or GSO 10:1 focuser in place of the original PST prism, using PTFE tape and fits well!
I had all OK, but the ITF with the whole PST original eyepiece holder held ... difficult to explain - unfortunately its thread is not same as standard diagonal or other similar bit and no x2 Barlow yet - I am doing visual.
I barely managed to glimpse The Sun and it seemed only slight out of focus.
It might make a better PST without the prism focuser!
Still cloudy, I have to got to my in-laws for Sunday Dinner soon.
Might try it later if it clears in the afternoon.
I cannot spend yet, so I am playing around a bit.
SolarChatted
Solar Gear:
Solar Gear:
- solarchatted
I got it working!
Far better focusing + more light getting through.
I tried it yesterday with camera too, but although sky was clear, it was quite hazy - today might be clearer and I am at work!
My only problem remains the how to attach PST eyepiece holder onto 'whatever' can hold it as it is a non standard ... I think I measured it at 32mm 0.75 pitch.
Not spent any money ... yet!
;p]
;p]
- PST single stack focuser mod
- PST_FocuserMod.jpg (109.89 KiB) Viewed 4769 times
SolarChatted
Solar Gear:
Solar Gear:
Nice mod!
- solarchatted
... I did use 3 blocks of timber wrapped in Gaffa/Cloth tape on the ring over the PST tube to avoid scratches!
I will have to find time to play a bit more with it.
It is much brighter and I might end up using the 7nm Filter all the time - if not too narrow.
One thing I do not understand ... some time ago I did try the Altair 178c [colour] and it was better than the 178M using a standard RED filter and also 7nm filter and set Sharpcap Histogram onto the RED which was obviously huge thanks to the filters !
Strange, as the Mono is a much better camera.
I need to find the videos and compare.
I wish I was retired and FREE to take telescope out ANY time is possible and also get ki**ed by my wife!
;p]
;p]
SolarChatted
Solar Gear:
Solar Gear:
- solarchatted
I forgot to ask something:
1.
The Bresser Messier AR-90/900 OTA Optical Tube Assembly https://www.telescopehouse.com/telescop ... embly.html, do I need to adjust tube length or not?
2.
Do I still have to take lenses off the PST Tuner if I use the above telescope?
Just trying to find a way to do it with minimal work, because I am not sure of anything and might 'waste' little money I have!
I have seen somewhere taking off the PST front glass and holder and push the whole tube in a telescope + the PST has the same mod I did above - with a SCT screw-on focuser!
If not - that is a HUGE plus and it probably is very light as well.
Thanks for your time - appreciated.
1.
2.
SolarChatted
Solar Gear:
Solar Gear:
- solarchatted
Here is one of the images I managed to take with SCT focuser one and wobbly nosepiece holder - nothing special, also a lot hazy.
But surface I believe it is clearer!
I 'think' this was with a 2x Barlow (with also 2x Barlow lens end screwed onto camera) - not sure ...
The Sun 22 May 2019 – 11:27UT PST (Single Stack) with SCT 10:1 Focuser test
Last edited by solarchatted on Mon May 27, 2019 11:19 am, edited 2 times in total.
SolarChatted
Solar Gear:
Solar Gear:
- solarchatted
I am now really tempted to get the Bresser Messier AR-90/900 OTA - I am not sure if I need to cut it or will work as is!
SolarChatted
Solar Gear:
Solar Gear:
