Appenzellersun, Polar Coelostat arrived , now in maintenance
Hi all
finally we came to an agreement. 12 pairs of shoes for an old famous coelostat :cheer:
that one has been built in Switzerland in the late 50's by Jakob Lienhard and has been sold to Germany in 1981. Now it's back to Switzerland again :cheer:
It needs now to be understood by me and refurbished, set up and aligned. Then we get pics (so I hope) with 8,3 m FL :woohoo:
a glimpse from the direction of the viewer
the light path
the reflecting mirror
The mirrors are in perfect shape, but have never been tested. They are uncoated at the moment. If I need more light, I can alwas coat the one or the other or both.
Has some body a manuel to this instrument , or is willing to help me to get it to run
One thing I tested so far, the clock runs wunderful
the light path
Re: Appenzellersun, Polar Coelostat arrived , now in maintenance
Is mirror at point A a parabolic mirror of 8.3 m focal length?
Ralph
Ralph
Looks like a wonderful project Walter, please keep us posted.
Hi Ralph, Hi Tommy
thank you very much.
Yes the mirror at point B is a parabolic with 8,3 m FL :woohoo:
- Has thanked: 20948 times
- Been thanked: 10588 times
Oh wow! A fine instrument there Walter. That was good value at just 12 pairs of shoes. I look forward to watching the project develop
- Has thanked: 8588 times
- Been thanked: 8324 times
Nice one, Walter. Looking forward to seeing how this progresses.
A wonderful clockwork project for a Swiss guy.
Yes we will be watching the Swiss clockwork on this one.A very interesting piece Walter. You will need a nice display case for this.
Cheers Derek
Cheers Derek
Hi Mark, Stuart and Derek
thank you very much. I'm very eager to get it run, test and then mount. I visited today a clockmaker to get an replacement of a little broken shaft in brass. He will do it for free because of that very rare instrument. I'm so happy.
Hi all
here I try to import a film taken of Jakob Lienhard in his obs in the 50'ies. Don't be afraid, your speakers work, but the film has no sound
the direct link
http://www.videoportal.sf.tv/video?id=9 ... ea6a28b328
the direct link
The video link does not bring you to an operable video!
Hi John
sorry I'm working on it. The direct link posted works for me at our solarchat site
Stephen: Please, I need your help to embed the video
That's a great vid Walter! I've tried to embed it for you but can't do it...
Hi Mark
thank you very much for your effort
First tiny step done
ordered a new part (just a one to one copy of the broken part). Should arrive in ten days.
Until then I read about grinding my own custom made mirror :woohoo:
Nice! Those are proper plans 8)
Hi Walter,
Very nice instrument. It is a version of Gerrish mount like the one built by my good friend Jim Daley http://stellafane.org/tm/tg/daley2/daley2.html
With the primary mirror having a 8 meter focal length and what looks like a 120mm aperture, it is most likely not a parabola but a sphere since it makes no difference optically at that long a focal length. You do have to worry about astigmastism thou since the flat mirror is feeding the primary at of axis angle. If you measure that angle I can raytrace the optical path and post a spot diagram and see if the astigmastism is problem. What is the diameter of the flat mirror ? I'm sure you know that the clock drive is tracking at 1 rev in 48 hours.
One of the draw backs of this design is the open optical path. You might consider enclosing it or setting up the optics over a grassy area.
- Dave
- Dave
Engineering = Take what you have and making what you need
Walter,
It looks like the writing on the back of the primary mirror is "R= 8360". If this is the case that usually means the the Radius of Curvature is 8360mm and the focal length will be 1/2 of this or 4180mm.
So the primary mirror needs to be this distance away from the focuser or the image won't come to focus and the diameter of the solar image will about 38mm.
- Dave
- Dave
Hi Dave
thank you very , very much for your comments. It happened while walking with our dog this afternoon that I thought about the figur R= -8360. Then I had a doubt about the 8 m FL.
Please can you confirm that the FL can be 4,2 m ? I'm sure the second mirror is "only" a spehere.
The flat mirror has a diameter of 200 mm, the collecting mirror a diameter of 150 mm.. What do you need to make your calculations ?
I'm most exited you chimed in
Walter,
The simplest method to find the focal length of the primary mirror is to use the Sun and measure the distance from the surface of mirror to the were the image comes to sharp focus. Since the mirror is both uncoated and also has a long focal length, there is no danger of catching anything on fire from the focused image of the Sun. The uncoated glass reflects only 5% of the light and the image is also very large so it is not strong enough to cause problems.
As for the angle to measure, if you look at the picture you posted with the light path drawn out, you need the angle that is formed between the optical path going up through the focuser and the light path being reflected off the flat mirror toward the 150mm primary mirror. Picture the light path as being a right triangle so you need the angle the primary is tilted so as to be aligned with the center of the flat mirror.
By the way, are you sure the primary mirror was mounted below the flat mirror ? I think the primary might have been mounted above the flat mirror.This would make the angle that the flat mirror needs to tilt to direct the light to the primary much smaller. Please see this article that gives examples of the typical optical arrangements http://articles.adsabs.harvard.edu//ful ... 9.000.html
- Dave
- Dave
Hi Dave
thank you very much for your help and also for the link of the article which I have found too. As soon as the sun Permits I'm going to measure the FL of the Primary mirror. I'll try also to measure it by m easuring the grinding depht of the mirror.
As for the setup I'm sure it is that way, otherwise the sun could not enter the focusing tube.
Please stay tuned
Please stay tuned
Hi all
we took the chance to measure the FL of the primary mirror. I have learned trough you:
R=2xf
well let's see what we end up with
the measuring team
searching for the reflections (not as easy as it may look)
close to the focal point
even closer
measuring point
the result
R=2xf
the measuring team
even closer
measuring point
the result
Walter,
I'll assume that the 4.045 meters is 1/2 the distance you measured to were the reflection of the lamp was in sharp focus. You should have measured 8360mm and 1/2 of that being the focal length or 4180mm. Most likely why you did not measure the 8360mm distance is that you need to place a screen next to the light source so they are co planar and move them together until the reflection is focused sharply on the screen. When you find that position, that will be the radius of curvature and 1/2 of that being the focal length. If you use parallel light as in Sunlight, then were the image comes to focus will be the focal length.
Here is a website that shows how to easily measure the radius of curvature using a flashlight and card board screen http://www.obairlann.net/reaper/astrono ... -test.html
- Dave
- Dave
Hi Dave
thank you very much for your help and the hints, but I don't agree at the moment. If the R of the spehre is 8360 I should find f around 4160 wich I have found with ~4050. Where do I mistake
Walter,
The light source ( your lamp) and the reflection off the mirror were it comes to sharp focus must be next to each other and you need to move them as unit until the reflection comes to a sharp focus. Please see the website I provide a link to.
Think of it this way, when a you look at a star the light comes to focus at the focal length of the mirror. As the object gets closer, the focus point moves more away from the mirror. When the light source is located at the exact radius of curvature, the focal point will also be at the radius of curvature and those distances will be exactly the same. If the light source is not at the radius of curvature, the light will come to focus somewhere BETWEEN the focal length and radius of curvature. So what you did was have the lamp located at some position but not at the exact radius of curvature. The mirror was farther away then 8360mm which caused the image to come to focus at 8100mm. So if you move the lamp closer the image would come to focus a little farther away. You keep doing this until both distance are the same, now your at the radius of curvarture. Also if you look at the mirror, it should totally fill with light, not just part of it or you see the lamb in it. The screen you focus the image on needs to be right next to the lamp and you move them as unit toward and away from the mirror until you find the position that the image is at sharp focus. When you do this you are forcing both the lamb and the focused image to be at the radius of curvature and 1/2 of that distance is the focal length.
- Dave
- Dave
Walter,
Think of it this way, when a you look at a star the light comes to focus at the focal length of the mirror. As the object gets closer, the focus point moves more away from the mirror. When the light source is located at the exact radius of curvature, the focal point will also be at the radius of curvature and those distances will be exactly the same. If the light source is not at the radius of curvature, the light will come to focus somewhere BETWEEN the focal length and radius of curvature. So what you did was have the lamp located at some position but not at the exact radius of curvature. The mirror was farther away then 8360mm which caused the image to come to focus at 8100mm. So if you move the lamp closer the image would come to focus a little farther away. You keep doing this until both distance are the same, now your at the radius of curvarture. Also if you look at the mirror, it should totally fill with light, not just part of it or you see the lamb in it. The screen you focus the image on needs to be right next to the lamp and you move them as unit toward and away from the mirror until you find the position that the image is at sharp focus. When you do this you are forcing both the lamp and the focused image to be at the radius of curvature and 1/2 of that distance is the focal length.
- Dave
- Dave
- sullij1
Very cool stuff boys! I will be lurking watching the action.
Look Up!
- Has thanked: 174 times
- Been thanked: 620 times
Walter,
What Dave is saying is position the torch immediately behind a hole in a large(ish) piece of card and locate that at 8300mm (near enough to start with.....)in front of the mirror.
When the lamp is pointed at the mirror the reflection should be seen on the card close by the lamp aperture.....slowly move the lamp/card until you get the best focus (of the lamp) on the card.
That will measure the radius of curvature, the focal length is half this....
Make any sense??
Make any sense??
Hi Dave, Hi Ken
thank you very much for your comment and help. We do not disagree. The test I used gives indeed the same result as your procedure described ( see also www.stathis-firstlight.de ). That procedure I used is a very common first test of a mirror while grinding it. I had the primary filter filled with light but was not able to take a pic of that situation because it reacts immediately of any little missalignment. Using the laser to measure the distance was just an additional check, and it works.
Next to that I meausred the curvature of the mirror, it is below 0,4 mm and above 0,3 mm, which gives the same result ~4,2 m focal length t= (D/2)2/2xR)
Hi mod gang
we are back again. I have received the broken part and I'm going to assemble the ceolostat the next weeks. Stay tuned.
Hi Walter!
Keep us all updated.
Hi Mark
I'm so happy that you have managed to get into the forum again too. I would have been feeling lost without you buddy. Did you notice that you have lost posting points as well as me. I'm a very new member to that forum, just joined it ;-) but I have already some hundreds post's ;-)
Hope you all over there stay dry (not meaning wine, beer etc. ;-) ) and safe
Very impressive Walter!
Please keep us posted
Hi Alex
thank you very much. I will :-)
Finally after 14 days without sunshine I took the chance to measure the FL in bright sunshine
The FL is 4180 mm. The diameter of the disk hitting the camera is ~45 mm
- focusedonthe sun.jpg (962.79 KiB) Viewed 4315 times
- thefocusedsun.jpg (665.14 KiB) Viewed 4316 times
temporary setup on the garden table
the swiss clock drive
Here you see also what has to be done regarding cleaning
The 12 o'clock position of the primary mirror
a riddle to be still solved (swiss hieroglyphs) Maybe somebody has a hint
the secondary temporarely positioned in the garden
finding a place higher up the facade
and now back inside
the workroom setup for cleaning
the first cleaned pieces, there are many many more to be cleaned
Hi Walter,
I think what the symbols mean is that if the Sun is drifting downward then you want to move the slow motion control in the direction the arrow is pointing to recenter the image.
- Dave
- Dave
- Peter Williams
This apparatus makes me think of:
"Alles Touristen Und Non-technishen Lookens Peepers!
Das Machine control is Nicht Fur Gerfingenpoken Und Mittengrabben.
Oderwise is Easy Schnappen Der Springenwerk, Blowenfuse, Und Poppencorken Mit Spitzensparken.
Der Machine is Diggen by Experten Only. Is Nicht Fur Gerverken by Das Dummkopfen.
Das Rubberneken Sightseenen Keepen Das Cottonpicken Hands in Das Pockets, So Relaxen Und Watchen Das Blinkenlights."
Interesting story of it's resurrection.
Peter Williams wrote:This apparatus makes me think of:
Hi Peter
DavidG wrote:Hi Walter,
- Dave
Hi Dave
very much. That is a good hint. We will see once installed
Hi Walter,
I'm interested in the clock drive. The two brass gears attached to the clock look to give a ratio of 1:1 so that means the clock motor itself needs to turning at 1 revolution in 48 hours to track the Sun. Have you measured it's speed ?
- Dave
- Dave
- Spectral Joe
Dave
It will be 1 revolution in 24 hours, because this is a heliostat, not a coelostat. A coelostat has the tracking mirror fixed in declination with it's surface coincident to the polar axis. To get the beam on the second flat the first flat's mount must be translated north-south as the Sun's declination changes. East-west translation is needed if the second flat shadows the first. A coelostat mirror rotates once in 48 hours and a polar heliostat once in 24 hours. There are a variety of other heliostat configurations, even altazimuth. A heliostat with anything other than the polar configuration will require two axis slow motions at rates depending on the geometry. If Walter's wonderful gadget is polar aligned it will track the Sun if it's turning once per day. Coelostats are more trouble to set up, but there is no image rotation as with a heliostat, which makes a difference in some cases. This is a photo of a coelostat, the tracks for translating the first mirror's mount are seen, the second flat has motor drives for tracking. Takes about a minute to acquire the Sun on average.
Joe
Joe
Not blind yet, either!
Hi Joe,
Thanks for jogging my memory about the Helio vs Ceolostat. I should have remembered the difference since I 'm restoring an original Hale spectrohelioscope that uses a Ceolostat.
- Dave
- Dave
- HALESHS.JPG (391.97 KiB) Viewed 4222 times
Hi Dave, Hi Joe
thank you very much for all your valuable Information.
@Dave yes it seems to be a 1:1 Ratio. I have not yet measured the Speed. I need to get it going, set up and have sunshine for some hours. Wow what a wonderful old piece you are restoring. Good luck.
@Joe thanks for sorting out heliostat versus coelostat. So then my gear is a polar Heliostat, right ? I'll bring it back, it was sold to me as a ceolostat
It is indeed aligned North/south, focuser beeing up north
All fascinating stuff, guys. Very interesting.
Good luck with the restorations.
Hi Stuart
thank you very much for the good wishes
Lovely to read how this has been developing Walter! Glad to see you making progress.
Hi Mark
welcome back. Hope you had a great time and the pocket full of pics. We missed you
