Blocking Filter, Mini ERFs and Alternatives
Re: Blocking Filter, Mini ERFs and Alternatives
Post by Merlin66 » Tue Apr 24, 2012 5:15 am
Sorry,
I still prefer calling the "Mini-ERF" a "mini-ERF" than a ITF - I think an ITF could be any filter....
The ERF in the SM60 etc is basically just a red filter....blocks below 600nm or so and passes everything above.
The curve above (for the "mini-ERF" not the blocking filter -title is incorrect) shows that it effectively blocks everything above 750nm
When the two are combined you end up with a bandpass of approx 600-750nm.
The Baader D-ERF has a narrow bandwidth (600-700nm) and blocks everything else (up to 1500nm).
Hope this helps.
etatsolarchat
Post by etatsolarchat » Tue Apr 24, 2012 6:18 am
If you want to replace the Mini-ERF(ITF) filter. I think a KG5 filter followed by a standard astro H-alpha filter would fit the bill..., right?
etatsolarchat
Post by etatsolarchat » Tue Apr 24, 2012 4:30 pm
Merlin66, For blocking filters I see 6A quoted in literature, how did you decide 6-8A? Would a spec of 7 be optimal?
Bob, what are you going to use instead of the KG5?
Post by Merlin66 » Tue Apr 24, 2012 5:01 pm
(what's your name?)
The 6-8A is based on the finesse and resonance of the various etalons used by amateurs....
The PST blocking filter(s) are very similar to the Lunt.....
DSobserver
Post by DSobserver » Tue Apr 24, 2012 5:10 pm
I just add a 23A red filter in front of my SM40 and now it works again using a KG5 filter!
Now I need good and clear sky to judge how much removing from filter, replacing (for the moment) with red filter and using KG5 instead of mini-ERF, it improve the picture.
"If you want to replace the Mini-ERF(ITF) filter. I think a KG5 filter followed by a standard astro H-alpha filter would fit"
Fully agree
Now regarding the BF, 6 or 7 or 8A doesn't care for the moment as the main point is to find them at a good price :whistle:
etatsolarchat
Post by etatsolarchat » Tue Apr 24, 2012 5:18 pm
Cool, I was thinking instead of an expensive H-alpha filter maybe a red 25 would work as well so let us know how the 23A red does for you!
DSobserver
Post by DSobserver » Wed Apr 25, 2012 5:17 pm
So this morning some quick test (before work and ...clouds :angry: )
As I said I'm using a DS PST and when removing front SM ERF and replacing the mini ERF with KG5, with red 23A filter is much better than without : I can see Ha sun. But it's still not perfect. The sun is bit orange and as soon as you tilt too much the SM it became green (again.... :X )
Most probably 23A is not enough. Could be that a 25A would be better.
I also could saw that apparently the rust on my mini ERF is affecting transmission 'cause picture is brigher with KG5 filter...
So :
1- I have to replace 23A filter with a "darker" one. I'll most probably use an Ha one and like this adding on top a KG5 I should be 100% IR/UV safe.
2- Find a solution to install my KG5 filter before BF and not after (on the eyepiece) as it is now. Any idea?
Post by marktownley » Wed Apr 25, 2012 6:17 pm
So :
What are the transmission curves for a 23a and 25a?
DSobserver
Post by DSobserver » Wed Apr 25, 2012 6:33 pm
Maybe this is of any use to you.
When I used my PST for photographic purposes I noticed that my mini-ERF (ITF) was heavily corroded, and found that a 35 nm H-alpha filter can be a good substitute. (Although I am not sure for visual use.)
ok for photo bud not safe for visual!
here is the 23A :
and here the 25A :
DSobserver
Post by DSobserver » Wed Apr 25, 2012 6:36 pm
Here are some filter curves.
Go to longpass filters and scroll down a bit to find the 23a and 25a curves.
faster :lol:
Post by marktownley » Wed Apr 25, 2012 7:28 pm
You'll get absolutely no difference with the 25a over the 23a.
Look carefully at the y - axis of the scales on the different graphs for the transmission curves for the 23a, 25a and ITF filters; the 23a & 25a are % transmission graphs, the ITF filter in an OD scale - the latter is logarithmic - considerably different magnitudes of transmission...
In a stock DS PST, I have to be honest here, not sure why or what the logic would be for removing the ITF unless it was rusted beyond use?
DSobserver
Post by DSobserver » Wed Apr 25, 2012 8:44 pm
Sorry but I don't follow both of your points :
Interest to replace mini ERF for a PST, a DS PST or a SM is the same I think....
Regarding transmission curve between ERF and red filter, you're right, but still don't understand why tilting the red one, the sun become greenish...
Post by marktownley » Wed Apr 25, 2012 9:37 pm
I think the absolute minimum if you want to replace the ITF is a nighttime Ha filter, the narrower the bandpass the better and appropriate KG glass.
If you tilt any filter, you blueshift it's bandpass, which is why I suspect you seeing your greenish sun when you tilt your red filter...
etatsolarchat
Post by etatsolarchat » Wed Apr 25, 2012 9:51 pm
I can see tilting a thin film filter changing characteristics, but how is that for a basic #23 red glass filter?
Stupid question #2, what machine is used to create these nice transmission plots? Never mind, Carl Zeiss M4-QIII Lab Spectrophotometer :cheer:
colinsk
Post by colinsk » Thu Apr 26, 2012 1:06 am
We really should describe a homemade spectrophotometer. It would not be that hard if you had a nice blazed grating. The rest could be salvaged or cheap parts.
Thank you, Here are some references I have collected.
Etalon Article Part I
Etalon Article Part II
Solar Patents of interest
etatsolarchat
Post by etatsolarchat » Thu Apr 26, 2012 2:32 am
Ok, I started a new thread for you :bow:
Bob Yoesle
Post by Bob Yoesle » Thu Apr 26, 2012 12:36 pm
Hi Etat,
First, if I had a failed ITF, I'd get it replaced with another ITF, as they are relatively cheap. And this is BY FAR the safest route to take in protecting ones eyesight from far IR... I would only consider alternatives for imaging - not visual - use. But even then, why risk a mistake in use?
Trying to replace (or in my case protect) the ITF with a optically poslished 2" KG5 has resulted in quotes of $425-$750 (uncoated) and it would cost another $100 + per filter for AR coating, and then additional funds for mounting in a tilted cell, whereas a new replacement BF30 ITF would be around $100-$200, be coated, and fit the existing tilted cell.
My reason to consider KG5 glass was to protect the ITF itself from any residual short and medium IR (thermal loading/cycling heat) passed by a sub-aperture Baader DERF in my future 152 mm scope, and to protect the CaK module's PST filters for the same purpose in my 130 mm APO. For H alpha my alternative will be a Baader Red CCD filter. It too is way cheaper than a polished KG5 (optical polishing is a neccessity IMO), and likely is a much better quality substrate.
For my CaK module (again imaging only) I'll employ the currently used Badder Blue CCD filter, with a Baader ND 3.8 film filter on the objective - I will have to see what the CaK exposures are with this set up to know if it is practical. If not, the "bare" Baader Blue CCD filter will have to do, and may have to be replaced if it fails down the road from excessive heat. Same cost issue as above - e.g. way cheaper than a polished KG5.
etatsolarchat
Post by etatsolarchat » Fri Apr 27, 2012 4:46 am
Awesome, thanks Bob. I'll follow your lead on the 152mm so eager to hear know how it goes!
Maybe if a bunch of us start pestering Baader, they's do a polished/coated KG5 and sell it for $100 ;)
Oh, the E, is for Eric maybe I can change that...
Post by marktownley » Sun Jun 24, 2012 7:19 pm
Just as a bit of further information on this post you may be interested in...
I recently compared the ITF from my BF10 with the ITF from my PST. They are different. The view through the PST one is brighter, and comparing views holding them up to the sky and viewing with naked eye, the PST one seems to pass more shorter wavelengths. Physically they also appear to be different filters; even though they are the same size, the PST one has a black cell that it sits in (similar I have to say to some of the Omega filters I have seen). Using either in combination with my PST mod results in reflections galore that reduces contrast. The best results I am getting with my PST mod is with the ITF removed and a peice of KG3 and Baader Neodymium in place...
colinsk
Post by colinsk » Mon Jun 25, 2012 2:51 am
OK
Let's walk through a PST...
The front objective is just AR coated - nothing special
The comes the tuneable PST etalon (Fabry-Perot etalon filter) - the heart of the instrument.
In the bottom of the eyepiece holder there's a small "Mini-ERF" to reduce the energy loading on the...
Blocking filter -positioned in the top eyepiece adaptor. This "sorts" the "comb" from the etalon and only allows the Ha bandwidth to pass through....
(In the Coronado BF diagonal there's also the "mini-ERF" and final blocking filter.)
Hope this helps.
This is for the new or repaired PSTs. The Gold objectives were:
ERF>Objective>Etalon>pentaprism>BF>EP
The first repair was the dark blue objectives and I don't know if the second piece of glass was added then. Then the second repair was
Objective>Etalon>Pentaprism>ITF>BF
I should note that I have seen both silvered pentaprisms and narrow band reflection coated Pentaprisms.
The narrow band reflection prism would leave green and blue out of focus suns inside the black box.
markthais
Oh, I get it now!
Oh, I get it now!
Post by markthais » Mon Jun 25, 2012 7:50 am
KG glass is good for cutting the IR. That is what it was designed for. The problem is that it is not like BK-7, it has strains and homogenous problems. But on the other hand if you keep it near the eyepiece end it should work fine. It is not a good choice at the objective end. You would be hard pressed to find a piece that would pass 1/4 wave on transmission at 650nm larger then 2".
They also mention that the etalon has band passes across the whole spectrum. Depending on the design of the mirror the etalon may only have peaks +/- 30nm from the center wavelength of Ha then it is just transparent to the rest of the visible spectrum.
The blocker + red glass cuts the short side. The long side the filter can start transmit again around 900nm. If you only have a KG glass there will be a leak in the red.
The idea of using one of Baaders 7nm filters and the KG glass used near the eyepiece end should block any IR.
The scan of the BF15 should look the same on both sides at the base. It should go to zero(OD4-5) on both sides. Either it's the scan or they missed and thickness on the layers.
The attachment shows an etalon and a two cavity 1nm blocker,
Post by Merlin66 » Mon Jun 25, 2012 8:03 am
Colin, et al,
I believe when the change was made to the "blue" objective, the "mini-erf" was either added (for warranty repairs) or incorporated into new builds. I haven't come across a "blue" PST without the "mini-erf"
Interestly, I also haven't come across a version where the pentaprism is silvered....
We/I need to get organised to take a wider spectrum (ie 400- NIR) of the various elements.
The data I published previously (see library files) has a limited wavelength coverage and doesn't (similar to Mark's) show the full spectral extent. Next job on the list!
(I also think the mirror in the Coronado BF diagonal is a "cold mirror" which adds another complication.....
Post by marktownley » Mon Jun 25, 2012 8:38 am
Very interesting input, thanks for that Mark :)
colinsk
Post by colinsk » Mon Jun 25, 2012 3:42 pm
I found this out long ago for my PST etalon. Unless you use a broadband mirror for the etalon coatings it will peak. I used a reflection grating and looked through mine at an incandescent bulb. The dark lines were confined to red and by green it was clearly broadband transmission. The peaks also got narrower and narrower as it moved from the design wavelength. This is of course easy to model in Excel if you enter a reflectivity curve because the finesse is reflectivity dependent.
Post by marktownley » Sun Jul 29, 2012 10:44 am
Check this out...
[ebay]150809975052[/ebay]
In particular the transmission curves - blocking out to 3000nm to ND5. This could well be an affordable and serious contender for replacing rusted ITF filters...
