Blocking Filter, Mini ERFs and Alternatives
krakatoa1883
Re: Blocking Filter, Mini ERFs and Alternatives
Post by krakatoa1883 » Sun Sep 30, 2018 3:04 pm
It was mounted just in front of a Powermate in my 150mm refractor. As I said above it was a cold winter day so it doesn't seem unlikely that it broke by a thermal shock.
The filter I am now using is this https://www.baader-planetarium.com/en/b ... ilter.html however for some unknown reason it is not compatible with my Quark in its original configuration, I had to remove the telecentric for making use of it. Same with my front Baader DERF.
Raf
christian viladrich
Post by christian viladrich » Sun Sep 30, 2018 3:24 pm
Interesting ... thanks for sharing.
http://www.astroplanetes.com/
Users browsing this forum: No registered users and 6 guests
