Solarscope Project
- The Sun?
Solarscope Project
This is a solarscope that I have been working on for the past few months. I uses a 180mm f12 lens and can use a PST mod 2 filter or a SHG that I built for it. It is a stationary horiz. scope fed by a heliostat 2 mirror system.
- IMG_0137.jpg (1.4 MiB) Viewed 1912 times
- The Sun?
Re: Solarscope Project
Additional photos
- IMG_0176.jpg (1.6 MiB) Viewed 1911 times
- IMG_0137.jpg (1.4 MiB) Viewed 1911 times
- Peter Williams
I'm frequently surprised and in awe of the things people on these forums build and modify.
Very cool stuff.
Very cool stuff.
Beginner amateur astronomer, keen on solar astronomy.
Geee,
The PST Stage 2 mod looks VERY similar to mine - I use the Borg #7315 focuser.....
The spectroscope looks very neat...are you using a 1200 or 2400 grating?
What do you use for the slit plate?
wow that looks good. welcome o that wonderful site, have sun, fun and mod the [hot place] out of it
Cool stuff! Welcome and keep us updated!
- The Sun?
Ken
I use a 1200 l/mm grating and a homemade adjustable slit. Using a xenon lamp I was able to obtain several emission lines but I need a different camera for the scope and SHG. For some reason I am unable to add more photos. The previous post shows a view of the heliostat that I built for the scope.
Ralph
Ralph
- IMG_0093.jpg (1.52 MiB) Viewed 1878 times
- The Sun?
- The Sun?
Additional photos
- IMG_0182.jpg (1.35 MiB) Viewed 1878 times
- IMG_0179.jpg (1.22 MiB) Viewed 1878 times
- IMG_0177.jpg (1.63 MiB) Viewed 1878 times
- IMG_0176.jpg (1.6 MiB) Viewed 1878 times
Hi Ralph
fine additions of pics
A cool piece of kit!
- The Sun?
Thanks
I now need to build the observatory to house it.
- The Sun?
I have finally installed the solar scope in an observatory and have done the preliminary installation of a coelostat to feed the solar image to the scope.
I am still waiting on the correct sync. motor to drive the primary mirror at the correct rate.
Ralph
Ralph
Too bad that the caelostat were build on so massive concrete. In a hot summer day this concrete plate
will produce amssive air turbulence. Images will be auful.
The rails and the pir should be mounted on the grass ground.
The best what you can do to exclude the massive turbulence is to cove the concrete by a wood
cover paited titanium white farb.
Valery.
Valery.
- The Sun?
I agree with your remarks. The pad was poured for the heliostat system which was housed in a sky shed POD which covered the pad. I plan to cover the concrete with foam insulation.
Ralph
Ralph
Wow, that looks cool!
I look foward to your results. A great project
