home nade 4 inch scope based on davidG hand held scope
- Has thanked: 57 times
- Been thanked: 1204 times
home made 4 inch solar ha-scope
I up scaled to 4 inch
100mm lunt ERF
50mm lunt tilt tuned ha unit used as internal etalon with proper 80X 400mm lens
b1200 lunt blocking filter
100mm lunt ERF
Re: home nade 4 inch scope based on davidG hand held scope
seeing was bad but results OK
- Been thanked: 10489 times
That is an excellent result!
better mount plus more stacked images = better results
Hi John
congratulations, a very fine job
What etalon is being used here?
Hi Mark
a luntLS50 see start of the post
Doh! I even read that last night, then forgot
- Peter Williams
Lots of spicules and other details, good work on building the scope.
Beginner amateur astronomer, keen on solar astronomy.
thx
it worked better than i thought
there is no barlow - that is prime focus
4 inch f/12 is a bit too long
im going to try a 4 inch with faster f ratio
so simply you can convert an external etalon
to internal etalon by just adding lens to make light parallel
why is this not done more often?
Hi John
another good shot
another good shot
- Peter Williams
Again a lot of spicule detail, good job.
seeing a bit off but still a scary surface
Hi John
a nice colored addition
