Page 1 of 1
Lunt L60 thread dimensions
Posted: Wed Apr 23, 2014 7:54 am
by _Zakalwe
Hello guys,
Do any off you know the thread specifications for the thread that the white barrel on a Lunt L60 has? The one that screws to the Etalon?
Re: Lunt L60 thread dimensions
Posted: Wed Apr 23, 2014 8:32 am
by marktownley
I think its 92mm, but may be wrong there. I'm sure someone else will chirp in.
Posted: Wed Apr 23, 2014 3:35 pm
by swisswalter
Hi Stephen
a year ago I could have measured it. No more LUNT 60 here. Sorry
Posted: Wed Apr 23, 2014 11:25 pm
by thesmiths
On my Lunt60 PT, the white tube has outside diameter of just under 90mm. The inside front thread, into which the front lens is attached, appears to have diameter of 86mm. I would assume the rear threads, into which the PT etalon is attached, would be the same. But please don't take my measurements as at all exact.
Posted: Thu Apr 24, 2014 1:21 am
by Sunwatcher
Would this info help? (See photos below.)
Measured across the top of the threads = 89mm plus just under 14 thousandths of an inch.
Measured across the bottom of the threads = 89mm plus 3 thousandths of an inch.
The serial number plate on the module.
Please don't consider these to be the most accurate measurments for use to cut threads on a lathe.
- top.jpg (113.57 KiB) Viewed 7304 times
- bottom.jpg (110.57 KiB) Viewed 7304 times
- dblstackmodule.jpg (114.97 KiB) Viewed 7304 times
Posted: Thu Apr 24, 2014 1:58 am
by Merlin66
Hmmm
I think he's looking for the external thread dimensions where the white tube screws into the internal etalon assembly on the Lunt 60...
I'm sure when we looked at the Lunt 60 etalon "mod" we noted these sizes....I'll need to check the drawings...
Posted: Thu Apr 24, 2014 2:02 am
by Merlin66
Looks like 86.5 x1....
- measurements of the Lunt60 (Viljo)
- Lunt60_sketch_own.gif (108.46 KiB) Viewed 7302 times
Posted: Thu Apr 24, 2014 5:37 am
by _Zakalwe
Perfect, thanks Ken. So its a metric thread, not some daft Imperial thing Good.
Posted: Thu Apr 24, 2014 10:18 am
by marktownley
Good job you didn't listen to me
Now I know though too...
Posted: Thu Apr 24, 2014 10:43 am
by _Zakalwe
I did some measurements over the weekend to see what sort of adapter I'd need to mount the Lunt L60 onto a Helios 120mm 'frac. I measured the diameter of the light cone that the Lunt objective produces at the front of the Etalon assembly. I then found the position in the Helios lightcone that gives me the same diameter.
The next step is to mock up an adapter, probably using the method that Viljo used- 2 pieces of hardwood to hold the Lunt OTA (obviously with the Lunt objective removed) inside the Helios OTA.
If that works then I can get an adapter made up in ally, hence the need to know the thread details.
Posted: Thu Apr 24, 2014 10:58 am
by _Zakalwe
One question. I don't yet have an ERF (will probably mount a sub-aperture ERF inside the OTA).
is it safe to do some quick test without an ERF? Or would the Lunt ERF be damaged?
Posted: Thu Apr 24, 2014 3:50 pm
by swisswalter
_Zakalwe wrote:One question. I don't yet have an ERF (will probably mount a sub-aperture ERF inside the OTA).
Hi Stephen
I guess you mean the LUNT Etalon being damaged , aren't you ?
Posted: Thu Apr 24, 2014 4:13 pm
by _Zakalwe
swisswalter wrote:_Zakalwe wrote:One question. I don't yet have an ERF (will probably mount a sub-aperture ERF inside the OTA).
Hi Stephen
Hi Walter,
The Lunt has the ERF mounted directly in front of the Etalon. I'm concerned that a 120mm objective would be pumping a LOT more energy into it than the native 60mm objective. I'm guessing that it would be OK for short periods of time? Enough to test focus?
Posted: Thu Apr 24, 2014 5:40 pm
by swisswalter
Hi Stephen
yes you are so right. I have forgotten it. I think for a very short time that should work without doing damage to the ERF nor the etalon
Posted: Thu Apr 24, 2014 9:38 pm
by _Zakalwe
The Frankescope..
Untitled by
Stephen Jennette, on Flickr
Untitled by
Untitled by
Hopefully, I'll get a chance to test it to the weekend.
If it works, then the next step is a sub-aperture ERF and a machined ally sleeve to replace the white Lunt barrel.
Posted: Thu Apr 24, 2014 10:13 pm
by marktownley
Cool fish! I look forward to seeing how you get on
Posted: Fri Apr 25, 2014 4:18 am
by swisswalter
Hi Stephen
that looks great. Wish you CS for the weekend
Posted: Sun Apr 27, 2014 11:08 am
by _Zakalwe
Well..I had a quick bash in very poor conditions and I cannot report success. I couldn't get the image to come to focus. I'm thinking that I perhaps need to recalculate my positions. Either that or something is not lined up, though I did use a laser collimator to get the solarscope on the optical axis.
Posted: Sun Apr 27, 2014 11:29 am
by swisswalter
Hi Stephen
good luck on the second try
Posted: Mon Nov 07, 2016 5:07 am
by solarmax2016
Its a 1 mm micro - hard to cut
SolarMax
