I have a lunt 100mm ERF and l am not sure which side to face towards sun as both sides look identical.Any help appreciated
Thanks
Lunt ERF question.
Re: Lunt ERF question.
Hi Gus
usually there is an arrow on the edge of the filter which should face the sun. In the worst case, you have only two trials to find out while imaging
- GUS
- Has thanked: 102 times
- Been thanked: 213 times
Thanks Walter, just had a look and could see no arrow. As i do not image, what other way to test-does it matter which side faces sun- is it safe to try visually both ways.
Thanks
Thanks
- Has thanked: 173 times
- Been thanked: 615 times
Yes, either way will be 100% safe.
If there's a coated reflective surface...this should face the sun , to prevent heat build up in the glass.
- GUS
Thanks Merlin, Lunt site says one side broadband AR coated and other side dielectric IR blocking coated.Looked at filter and noticed one side is deep red and other side slightly less red, with a tint of purple.Would it be safe to say the redder side is broadband AR coated.
Thanks.
Thanks.
- Been thanked: 3 times
Hi, in my opinion the slightly purple side should face the sun, this should be the IR coating. My ERF has a similar colour and has always been that way round as advised by Schotts when purchased. Hope this helps, John.
- Has thanked: 20424 times
- Been thanked: 10243 times
I agree with Sungazer
