my little lunt60 mod
Re: my little lunt60 mod
Post by swisswalter » Wed Jun 04, 2014 4:07 am
Hi John
thanks a lot for the size information
highfnum
Post by highfnum » Fri Jun 06, 2014 10:27 pm
some more test first with .60 reducer
highfnum
Post by highfnum » Fri Jun 06, 2014 10:29 pm
with TV 2.5 barlow
shows pretty good resolution
highfnum
orig B+W
Post by marktownley » Sat Jun 07, 2014 5:17 am
Nice shots with the mod!
highfnum
Post by highfnum » Sat Jun 07, 2014 1:54 pm
THX
I like this mod
completely reverseable no change to Lunt scope it self
Post by MapleRidge » Sun Jun 08, 2014 8:47 pm
Great results from the modded scope!!!
vikeljay
Post by vikeljay » Sat Jun 14, 2014 12:25 pm
Just what does this mod do? Also, where can I pick up that convex lens? Thanks.
Jim
highfnum
Post by highfnum » Mon Jun 16, 2014 10:46 pm
I got mine at Edmund optics
I bet If I tried I could have found one for less money
Reason for Mod
My idea was to get more resolution 60mm vs 75 mm out of same scope
second slightly faster f ratio for brighter image so when I use Barlow I got more light to work with
and do it so it was reversible without changing original spec of scope
highfnum
Post by highfnum » Sat Jun 28, 2014 11:06 am
i tried this mod with cheap 4 dollar lens to see if
results would equal 80 dollar lens
forget it
disk had poor detail
i got
one more
90 by 300 mm
ill get back
Post by swisswalter » Sat Jun 28, 2014 2:20 pm
Hi John
good luck, we are expecting results asap ;)
highfnum
Post by highfnum » Sun Jun 29, 2014 7:19 pm
ok I did preliminary test with 90 X 300 mm lens
I used tape and foam rubber for now i cant promise lens was optically square
but initial l test look good
here is first shot
highfnum
Post by highfnum » Sun Jun 29, 2014 7:22 pm
lens position is critical to get sharp image
Im to close to etalon as you can see
I had to add 2 tubes to get to focus
but I will build proper lens mount and fins its proper position (I hope ;)
Post by swisswalter » Sun Jun 29, 2014 9:49 pm
Hi John
yes it is all about sharpness and contrast dealing with distances. Good luck
highfnum
Post by highfnum » Sun Jun 29, 2014 9:55 pm
so far first mod is best - 75mm by 250
I guess the 80 dollar lens was worth the money
ForrestLockhart
Oh, I get it now!
Oh, I get it now!
Post by ForrestLockhart » Fri Jul 04, 2014 9:55 pm
Hi John,
How does the lens setup perform visually?
Forrest
Forrest
Lunt LS60T, TeleVue NP-101 refractor, 100mm Lunt Engineering refractor, 80mm StellarVue refractor, Lunt Herschel wedge, full aperture solar filters
highfnum
Post by highfnum » Sat Jul 05, 2014 4:04 pm
75mm (edmund) lens works just fine visually
a litter brighter
OK
i tried with 90mm lens and changed position
also cut lens down to 83mm
I also changed position
and got what I consider second best results
75mm is still sharper
but 30 dollar lens did OK see for yourself
highfnum
Post by highfnum » Sat Jul 05, 2014 4:05 pm
one more shot
highfnum
Post by highfnum » Sat Jul 05, 2014 4:08 pm
above shots - no barlow
I did need (1) 4 inch extension tube due to longer focus
so here is my final config for this mod is a get a better quality lens then ill flip it
highfnum
Post by highfnum » Sat Jul 05, 2014 4:10 pm
one more thing notice my june 28 shot was much softer before final changes
and quality of lens (DUH :D )
highfnum
Post by highfnum » Sat Jul 05, 2014 4:19 pm
to JIM
I used edmund part # 63495 Lens PCX 75 X 250 MGF2 CTD
the 90 I gotta find papers I know its 90 X 300
all millimeters
soulvagabond
Oh, I get it now!
Oh, I get it now!
Post by soulvagabond » Wed Nov 30, 2016 6:11 pm
Seems like a good looking and cheap mod.
I will probably be purchasing a lunt ls50 shortly, so really curious, if this upgrade can also be applied. What lens size would be more appropriate, since, LS50 focal ratio is F/7, against 60's f/8.3
highfnum
Post by highfnum » Sat Dec 03, 2016 11:23 pm
try to stay within original f num give 10 pct
soulvagabond
Oh, I get it now!
Oh, I get it now!
Post by soulvagabond » Mon Dec 05, 2016 11:44 am
Thank you,
I'm a bit confused here, Lunt 60 has native f/8.3 and the convex lens you used is f/ 3.3
What's the logic behind calculating the right lens fot Lunt 50 then?
Please, bear with me, my optical knowledge is pretty vague.
highfnum
Post by highfnum » Mon Dec 05, 2016 12:33 pm
Correct lunt has built in telecentric Barlow
Lunt native lens is very short also
If you unscrew it and test you see what I mean
