New 150mm PST Mod Project
This will be my 3rd PST mod . First I would like to thank the many talented people here for sharing their valuable information here and also a big Thank You to Stephen for this amazing site .
This scope is actually 3 scopes combined . Starting at the aperture end I used an old Aopgee 127mm , the dew shield on this scope is slightly larger than 150mm and will not obstruct the light cone . I will need to make a mounting ring to hold the objective cell that will extend the cell 2" from the end of the dew shield , this way the light cone will clear the hole where the 127mm lens used to sit .
Next I needed a way to extend the tube to bring this to 1500mm . The Celestron 102 XLT that I used for my first mod was just the ticket . First I made a guide ring that can be threaded to the end of the 102 that would fit snug into the Apogee 127 tube , Then I made an end cap for the 127 that would fit the 102 tube and lock it into place . By combining these two scopes together I was able to leave the baffles in place .
The ERF is a 100mm Lunt and is mounted in a PVC cell and slides into the 127 tube , the glass can be tipped within the cell if required . The cell will be held in place with 3 small screws .
I had previously used this 102 for my first mod so the back end was all ready set up to accept the stage II PST mod .
This is what I ordered for the aperture , it arrived on Saturday and I will be leaving shortly to pick up the aliminium I will need to mount it
Here is a view of the complete configuration , if it works I might even paint it to tone down the Frankenscope look !
Re: New 150mm PST Mod Project
Hi Mike
that's going to be a fine mod with the ISTAR lens
- Has thanked: 8596 times
- Been thanked: 8327 times
I can certainly vouch for the ISTAR lens.
Good luck with your first light.
- Has thanked: 20962 times
- Been thanked: 10597 times
Very good indeed! I look forward to watching how it develops!
Thank you for the positive comments guys , having Solarchat mekes it easy to follow in others footsteps .
I picked up the aluminium I needed to mount the lens cell on Saturday and had it all ready to go late Sunday . Here is a shot of the aperture mounted and a shot of the completed scope . The good news is that it worked . I was able to get some first light images yesterday and will post them in another thread with my initial findings shortly .
Hi Mike
what a fine setup
what a fine setup
Thank you all for your positive comments .
I have made a couple of changes to complete this project . First big change was to replace the original 127mm lens cell that was holding the dew shield to the main tube . This was plastic and the dew shield just slid on and was nothing that I wanted to trust to support the 150mm Istar objective . So I made another aluminium ring to securely join the dew shield to the main tube .
I didn't like the "cobblescope" appearance so I gave it a paint job to give it a more professional look .
The last issue was my mount , My GM8 didn't like this much load and the tripod legs would get in the way of the scope . Walter suggested a G11 would handle this scope and I am sure it would but I found a nice used EQ6 Pro mount on a column type base . This base has wheels and jack screws with no legs to interfere with the scope . I am very happy with how this all turned out , just waiting for some sun now .
Hi Mike
yes very fine, you are ready for the first light
- Has thanked: 200 times
- Been thanked: 102 times
Hi Mike,
That is a brilliant finish to your mod. The pics of your images using this scope are a treat too.
Nice job.
Fraz.
Nice job.
Fraz.
Stage 2 mod completed @ 100, 127.
Istar 228 arrived, building the frame slowly while learning cnc.
- pedro
- Has thanked: 14 times
- Been thanked: 6754 times
Great mod Mike. I love the final result (OTA)
Pedro Re'
Thanks for the comments folks , it rides much smoother in the EQ6 . All I need now is some clear sky's
One last thing to do on this mod and that is to add a second motor from Moonlight to adjust the etalon . I have ordered the motor and my hand control has 2 channels so if it all works I will have focus as well as etalon control on the same hand control
Hi Mike
once done please post a pic or two
Glad to see this is coming along well!
Very nice, indeed.
Looking forward to seeing the results.
