Sun funnel repairs
wkyee
Sun funnel repairs
Post by wkyee »
My sun funnel has completely come apart. To be specific, the rear projection screen material tore away from the pipe-clamp that was holding it to the funnel. I am left with a disk of material that is barely larger than the diameter of the opening of the funnel. My guess it that I just had it stretched too tight, and over time it tore.
So, can I re-attach this to the funnel with crazy glue or some other adhesive? O must I resort to buying another piece of this stuff?
Dr. Willie Yee
President, Mid-Hudson Astronomical Association
Commander, Prius-class shuttlecraft Zhang Heng
Been thanked: 1 time
Re: Sun funnel repairs
Post by swisswalter »
Hi Willie
has it become brittle ? If yes, replace it, if not go ahead with welcro
Has thanked: 20732 times
Been thanked: 10427 times
Just replace the material screen I guess?
