Blackfly 5.0 MP Mono GigE PoE
papamidnight
Post by papamidnight »
Anyone tried this camera? Seems exceptionally cheap compared to other 5mp monos (probably with good reason right?)
_Zakalwe
Has thanked: 68 times
Been thanked: 56 times
Re: Blackfly 5.0 MP Mono GigE PoE
Post by _Zakalwe »
Lots of chip for not much money.
The same sensor is being used in the new QHY5P-II camera too:
http://qhyccd.com/ccdbbs/index.php?topic=4738.0
Has thanked: 156 times
Been thanked: 893 times
Post by Valery »
papamidnight wrote:Anyone tried this camera? Seems exceptionally cheap compared to other 5mp monos (probably with good reason right?)
Too low speed for good resuls if a high resolution is the goal, IMHO.
Valery.
GreatAttractor
Has thanked: 748 times
Been thanked: 757 times
Post by GreatAttractor »
I could live with the framerate (in good seeing 390 frames captured over 30 seconds would be enough for successful stacking), but this camera has only rolling shutter.
My software:
My images
