UK/Switzerland Newton mod to a solar gun
Been thanked: 1 time
Re: UK/Switzerland Newton mod to a solar gun
Post by swisswalter »
Hi Mike
good luck with the stripping
thesmiths
Has thanked: 47 times
Been thanked: 1522 times
Post by thesmiths »
Walter+Mark: I also did not spend a huge amount of time on my 5 inch solar Newtonian. But in theory this approach ought to give extremely good results with CaK. It definitely worked well but of course it's difficult to truly compare unless the comparison is side to side, on the same day, etc.
So solar Newtonian plus Quark would be difficult to make work? If the mirror is large enough there really is still quite a bit of light.
By the way, if the mirror is of fairly large diameter (like 8 inch and above), I think it's actually better to do without the diagonal (secondary) mirror and mount the camera (plus any filters) at the top of the open tube. The central obstruction at 8 inch and above will be equal or less and there is greater flexibility in reaching focus.
Hi Douglas
yes you are right, working without the secondary leaves us mor freedom reaching focus. I doubt that the heat load for a Quark is too high, at least when we use only a stripped 8" mirror
Has thanked: 20743 times
Been thanked: 10439 times
It's whether a stripped mirror would leave a quark enough light; the quarks are designed for 100% throughput hitting them, not the 5% reflection of the stripped mirror. I guess it's all good and well me debating the theory, the proof of the pudding would be to try it...
Hi Mark
I would like to do the test coming weekend, above all, best weather forecast, but I'm out of town, sorry
