UK/Switzerland Newton mod to a solar gun
Hi Freaks
on sunday 17th August Mark T and walter modded a 8" Newton to a solarscope. We were lucky to get at least a proof of principal in WL and CaK. We did not have time to collimate the scope. so no pretty pics. Now we wait for the second light
the mirror in the ferric chloride bath
only solarchat members can do that so fast , the decoated mirror
looking down the tube
looking up the tube
first we saw only reflections
the first WL
the first CaK
looking up the tube
the first WL
the first CaK
Re: UK/Switzerland Newton mod to a solar gun
Hi Walter,
international cooperation works! It sound well but I didn't understand how you get the image once the mirror is no more a mirror ??
Play in the sunshine, we're gonna get over !!
Hi Marcello
thank you very much. The rest reflection of pure glass ~4% is enough to get enough light. We did not strip the secondary
- Has thanked: 8559 times
- Been thanked: 8290 times
Very interesting, Walter/Mark.
Looking forward to seeing more.
Hi Stuart
thank you very much. We can't wait to see some sunshine
- Been thanked: 10489 times
This was a very fun day Walter! I'm seriously thinking about getting a 6" f8 reflector and stripping the mirror like we did (I can do it in the lab at work) and using it for Hi-res whitelight and CaK, it's certainly a cheaper option than getting a 6" frac...
Hi Mark
yes that was fun. Next time you visit Switzerland we will strip a 6" SC
- Been thanked: 171 times
Hi Derek
thanks for the flowers
Hi Markmarktownley wrote:This was a very fun day Walter! I'm seriously thinking about getting a 6" f8 reflector and stripping the mirror like we did (I can do it in the lab at work) and using it for Hi-res whitelight and CaK, it's certainly a cheaper option than getting a 6" frac...
a decent offer
15 cm f/8 Newton auf AOK WAM 40 Montierung
Grosses Bild
Zu verkaufen: 15 cm f/8 Newton mit Rotationssystem, stabilem Delit-Tubus, Metall-Hauptspiegelzelle, NGF3-Auszug, guter Optik auf AOK WAM 40 Montierung mit DD1-Steuerung und Gegengewichten auf sehr stabilem Stativ. Ideal für Beobachtungen und für Schnappschüsse von Mond und Planeten. Die Nachführung in Rektaszension läuft, der Deklinationsmotor funktioniert nicht. Ob das Problem an der Steuerung, dem Motor oder der Mechanik liegt weiss ich nicht. Das Achsenkreuz weist aufgrund des mobilen Einsatzes Kratzspuren auf und ist alleine 21 kg schwer (deshalb ist die Montierung nichts für Kinder). Das Fernrohr mit Optik wiegt 11 kg. Komplettset sFr. 300.-
Inserenten-Details
Email : Inserent kontaktieren
Land : Switzerland
Anzeigen-Details
Anzeigen-ID : 3352
Ansichten : 319
Hinzugefügt : 2014-08-18 12:48:50
http://pinboard.astronomie.info/detail.php?siteid=3352
That is a good price!
Hi GUS
thank you very much
thank you very much
- astroshot
- Has thanked: 335 times
- Been thanked: 252 times
There doesn't seem to be a multi-point mirror cell.
Is that simply the design of that particular scope?
Would a multi-point mirror cell reflect additional light in a fragmented manner back up the tube?
I suppose a sheet of flocking paper could be used, although it could be a heat trap.
Michael in Kildare, Ireland.
TEC140
Coronado Solarmax 90
Daystar 0.6A T-Scanner
TEC140
Hi Michael
thank you very much. Yes that is just the original design of that scope with three adjusting points on the rim of the mirror. The influence of a black paper on the back of the poliished side has yet to be tested. What we noticed the first time we had the scope pointing at the sun was not a noticable warming at all
Walter, nice project. I stripped my 6 inch mirror with undiluted pool acid - HCl. works great, but the fumes will knock you unconscious.
You also have to put a black board behind the mirror to boost the contrast. And dont forget the UV/IR blocker!
See here:
http://schursastrophotography.com/solar ... icle1.html
See here:
Chris Schur
Hi Chris
thank you very much. Very valuable information on your home page
- Has thanked: 47 times
- Been thanked: 1525 times
Very cool. I've been out of astronomy action for the summer. This reminds me to get back to work and do more work on my solar Newtonian. Is there any way to make this concept work with H-alpha?
Hi Douglas
thank you very much. I have not looked into that so far but surely will later in the year. I guess we need first a very strong focuser with full 2" opening for a TZ system
thesmiths wrote:Very cool. I've been out of astronomy action for the summer. This reminds me to get back to work and do more work on my solar Newtonian. Is there any way to make this concept work with H-alpha?
This is something i've been given much thought to, but there is no obvious answer.
Hi Mark and Douglas
my biggest concern is, not enough light, at least for HIRES shots. That is the reason why that mod stands behind the other five I'm working on
- grimble_cornet
- Been thanked: 47 times
Very interesting project guys. I have an old 6 inch mirror (from a home made Newtonian ......long, long ago) which I have been thinking of stripping for solar use. Is the ferric chloride solution the same stuff that is used to etch circuit boards (another hobby from the past)?
Mike
Mike
Mike Garbett
Mike Garbett
grimble_cornet wrote:Very interesting project guys. I have an old 6 inch mirror (from a home made Newtonian ......long, long ago) which I have been thinking of stripping for solar use. Is the ferric chloride solution the same stuff that is used to etch circuit boards (another hobby from the past)?
Mike
Yup, that's the stuff!
- grimble_cornet
Thanks Mark; sounds like a nice project for the winter months
Mike Garbett
Mike Garbett
Hi Mike
good luck with the stripping
Walter+Mark: I also did not spend a huge amount of time on my 5 inch solar Newtonian. But in theory this approach ought to give extremely good results with CaK. It definitely worked well but of course it's difficult to truly compare unless the comparison is side to side, on the same day, etc.
So solar Newtonian plus Quark would be difficult to make work? If the mirror is large enough there really is still quite a bit of light.
By the way, if the mirror is of fairly large diameter (like 8 inch and above), I think it's actually better to do without the diagonal (secondary) mirror and mount the camera (plus any filters) at the top of the open tube. The central obstruction at 8 inch and above will be equal or less and there is greater flexibility in reaching focus.
Hi Douglas
yes you are right, working without the secondary leaves us mor freedom reaching focus. I doubt that the heat load for a Quark is too high, at least when we use only a stripped 8" mirror
It's whether a stripped mirror would leave a quark enough light; the quarks are designed for 100% throughput hitting them, not the 5% reflection of the stripped mirror. I guess it's all good and well me debating the theory, the proof of the pudding would be to try it...
Hi Mark
I would like to do the test coming weekend, above all, best weather forecast, but I'm out of town, sorry
