120 mm modification PST
JF Roudier
Post by JF Roudier »
good evening,
I propose a modification PST with a telescope 120mm FD 15, which has a glass lens Schott RG 610 This will not put an ERF filter in front.
http://www.astrosurf.com/jiaifer/pagelunette120.htm
I make a change with Mak M703 and a Baader ERF 180, as well as a telescope Istar 150 FD 10.
I will keep you informed of the results.
Thank you for your visit, Sincerely,
Jef
Has thanked: 20755 times
Been thanked: 10441 times
Re: 120 mm modification PST
Welcome to the forum Jef, keep us updated :)
Been thanked: 1 time
Post by swisswalter »
Hi Jef
welcome to that wonderful site, have fun in the sun and post as much as you can
