Solar finder
Solar finder
Post by swisswalter » Thu Nov 17, 2011 5:59 pm
Hi all
just in case some newbie want's to make his owne solar finder for a dime
Re: Solar finder
Post by Montana » Thu Nov 17, 2011 7:34 pm
That's great Walter but how do you make the bit of metal?
Re: Solar finder
Post by marktownley » Fri Nov 18, 2011 12:00 am
Brilliantly simple idea walter!
One of my students in my Product Design class (he's also in my astronomy class and has the school PST on long term loan) is designing a solar finder as part of his final year project. He has quite a few interesting (and subtley different) ideas for prototypes for finders which I hope we can post out for people to try and report back with feedback in the near future. It would be a great help for his project and I think you kind folks here would find interesting and beneficial.
Watch this space!!! :)
Bill E.
Re: Solar finder
Post by Bill E. » Fri Nov 18, 2011 1:14 am
Mark ,I will be looking forward to your future post.
Re: Solar finder
Post by swisswalter » Fri Nov 18, 2011 5:17 am
Hi Alexandra
yes it is as Apollo pointed out, a PC slot cover. Just bent on each side and a drilled hole. Attached with a double sided tape to the OTA
Roel
Re: Solar finder
Post by Roel » Sun Dec 04, 2011 9:13 am
Good job!
When you drill a hole at the location of the cross and stick a piece of masking tape over it, you can see the projected image of the sun from the eyepiece side of the telescope. This is how I built mine:
My sketches, observations and ATM projects: www.roelblog.nl
Pedro
Re: Solar finder
Post by Pedro » Sun Dec 04, 2011 11:37 am
Gerat idea. I used a comercial solution to fit a solar finder to my LUNT 152 (had to work for 10 min at my workshop to fit the finder to the OTA). Interesting that an expensive telescoe like the LUNT 152 does not have a solar finder...
solarchat
Site Admin
Site Admin
Re: Solar finder
Post by solarchat » Sun Dec 04, 2011 1:38 pm
Pedro,
The LS152 does not have a solar finder on purpose. The rings have an identical right angle shape built in to both of them so that you look for the shadow of the first ring on the second one and then align the shapes together. I wish that every solar scope used this because it never needs aligning or adjusting and it is always 100% correct and centered.
Stephen W. Ramsden
Atlanta, GA USA
http://www.solarastronomy.org
Pedro
Re: Solar finder
Post by Pedro » Sun Dec 04, 2011 3:07 pm
Hi Stephen:
You are of course right and I read this in the available documentation. However the use of a solar finder (sol searcher) is a better way to find de sun. The shadows inside an observatory sometimes are not easy to manage. With the FS128 I use the projection of my Taka 50x10 finder to center the sun.
best regards
vidman
Re: Solar finder
Post by vidman » Sun Dec 04, 2011 3:44 pm
Great idea
Chuck
Solar Noobie learning from the Best group around.
Nighttime Astro-Nut (Not "sissy" stuff...we have to deal with wild animals and cold in the dark...LOL)
Roel
Re: Solar finder
Post by Roel » Sun Dec 04, 2011 7:35 pm
I believe the most convienient way to center the sun is when you can actually SEE the projected image of the sun from a position behind the eyepiece. To find the Sun using the tube ring method requires standing up an look on the other side of the tube ring. The Televue finder with its semi transparent projection screen method (or a "walter"-design) close to the euepiece) does not.
Re: Solar finder
Post by swisswalter » Sun Dec 04, 2011 8:09 pm
Hi Roel
thank you for your thoughts. I'm not fishing for compliments, but the "walter design" is so simple, straight forward, easy to make and handle and cheap. It should get a nobel prize ;-)
Re: Solar finder
Post by swisswalter » Sun Dec 04, 2011 9:00 pm
Hi Theo
thank you very much ;-) I'm honored
iwatkins
Re: Solar finder
Post by iwatkins » Sun May 13, 2012 8:34 pm
Holy thread resurrection Batman!!
Mark,
If your student needs a tester, just yell. :)
I like nothing better than having a tinker in the workshop, you know, cut some metal, hit with a hammer, paint or polish. I'm not very good but it relaxes me. I'm looking and making myself a nice solar finder for the big frac. using a 50mm tube to go on the finder bracket/rings. So I'm interested in any weird and wonderful designs anybody can point me to.
Cheers
Ian
Re: Solar finder
Post by marktownley » Sun May 13, 2012 9:11 pm
I'll dig one out for you ;)
peter drew
Re: Solar finder
Post by peter drew » Mon May 14, 2012 9:39 am
I use a stock 30mm finder with a 6mm hole in the objective cover cap with a piece of solar film glued to the inside face. It still works as a dust cover. :)
Re: Solar finder
Post by swisswalter » Mon May 14, 2012 4:17 pm
Hi Peter
great idea, but my bent PC slot cover is still cheaper :P
dragoncity
Re: Solar finder
Post by dragoncity » Tue May 15, 2012 10:28 am
Theres a nice collection of Solar Finders on this .PDF file
http://www.dd1us.de/Downloads/a%20colle ... %200v4.pdf
I knocked up a #12 from scrap ali tubes, MDF 'timber' and it works great. The main advantage of #12 is that its self aligning to any non-tapered scope tube. I simply rubber band it to the SolarMax. Alignment in 5 seconds its that easy.
