Appenzellersun, CaK filter change
Post by swisswalter »
Hi freaks
the summer was no good here, so very little chance to try out mods but now we had the second autumn day with sunshine :)
CaK full disk with UV/IR cut and K-line (23.09)
CaK full disk with IR-cut and K-line (24.09)
CaK full disk with additional UVB filter (baader venus filter) (24.09)
CaK full disk without K-line, only baader venus filter (24.09)
my conclusions: with my setup, it is of advantage to not use a UV/IR cut filter, instead I should use only an IR cut filter and replace the K-line double stack by a single UVB filter (Venus). Tests with a single K-Line have to be done though asap
grimble_cornet
Been thanked: 47 times
Re: Appenzellersun, CaK filter change
Post by grimble_cornet »
Very interesting results Walter - thanks for sharing.
Mike Garbett
Hi Mike
thank you very much
Has thanked: 20813 times
Been thanked: 10484 times
interesting to see this, a venus filter is on my list too...
thesmiths
Has thanked: 47 times
Been thanked: 1525 times
Post by thesmiths »
Walter, just to be clear, you're using the yellow Lunt stack in combination with the filters mentioned here?
Hi Douglas
yes. The setup is as follows lunt hot mirror, lunt Cak stack filter, (K-line, or Venus or both), PST CaK filter #1, IR-cut
