Hi freaks
the summer was no good here, so very little chance to try out mods but now we had the second autumn day with sunshine
CaK full disk with UV/IR cut and K-line (23.09)
CaK full disk with IR-cut and K-line (24.09)
CaK full disk with additional UVB filter (baader venus filter) (24.09)
CaK full disk without K-line, only baader venus filter (24.09)
my conclusions: with my setup, it is of advantage to not use a UV/IR cut filter, instead I should use only an IR cut filter and replace the K-line double stack by a single UVB filter (Venus). Tests with a single K-Line have to be done though asap
Appenzellersun, CaK filter change
- grimble_cornet
- Been thanked: 47 times
Re: Appenzellersun, CaK filter change
Very interesting results Walter - thanks for sharing.
Mike Garbett
Mike Garbett
Hi Mike
thank you very much
thank you very much
- Been thanked: 10247 times
interesting to see this, a venus filter is on my list too...
- Has thanked: 42 times
- Been thanked: 1487 times
Walter, just to be clear, you're using the yellow Lunt stack in combination with the filters mentioned here?
Hi Douglas
yes. The setup is as follows lunt hot mirror, lunt Cak stack filter, (K-line, or Venus or both), PST CaK filter #1, IR-cut
