Big AR small scope
papamidnight
Big AR small scope
Post by papamidnight »
Couple of shots from my 90mm, hershel wedge and chameleon.Anyone know how to do a gif in CS2? There doesnt seem to be an align frames script :(
sunspot 2 small.jpg (159.22 KiB) Viewed 3012 times
big spot small.jpg (127.54 KiB) Viewed 3012 times
Been thanked: 1 time
Re: Big AR small scope
Post by swisswalter »
Nice shots.
for gifs I use GIMP. Very easy and free
papamidnight
Thanks Walter! Is there a way to align frames in Gimp? I have 30 for the animation.
grimble_cornet
Been thanked: 47 times
Post by grimble_cornet »
Great close-up image.
Align in Registax and export as individual images?
Mike Garbett
papamidnight
Hi Mike! Will Registax output aligned but non-stacked images? Thanks for any assistance!
papamidnight
Heck, registax will output an aligned AVI and you can even choose the frame rate. Thanks for the suggestion!
Over 1.5hrs unfortunately the big spot didn't change enough to make a useful movie.
Hi Scott
for aligning you can also use IMGALT, it's free and works perfect
GreatAttractor
Has thanked: 747 times
Been thanked: 753 times
Post by GreatAttractor »
To get imgalt, follow the link in my signature. But keep in mind that it will align image sequence on the most prominent feature, i.e. The Monster, and not on the limb.
My software:
My images
Hi Filip
will there be in the future something like a Point Setting that imgalt is reffering to while doing its job ?
GreatAttractor
Walter, that's one of new functions I'm considering.
My software:
My images
Thank you Filip. I'll be happy to test it as soon as you have it implemented
