Change Focuser Double-Stack Meade/Coronado SolarMax II 90?
124Spider
Post by 124Spider » Thu Oct 30, 2014 5:08 pm
New member here; first post.
I just got a Coronado (Meade) SolarMax II 90, double-stack with BF15 blocking filter (integral to the diagonal). I was lucky, and was able to use it a bit on the day it arrived.
I like it very much, except, at first blush, I'm not too thrilled with the helical focuser. I have good focusers on my other scopes, and so I'm spoiled by the ability to lock the focuser from moving, and to fine-focus. And I like the idea of not being forced to use a diagonal (for instance, when I start imaging with this scope).
MoonLite makes a focuser that they say fits, with some surgery (I haven't gone into details, but I suspect that it involves moving the blocking filter).
Has anyone here successfully retrofitted a quality Crayford-type focuser onto this scope? If so, was it worth it, and what was involved?
Thanks!
Mark de Regt
Redmond, Washington, USA
Coronado (Meade) SolarMax II 90 Double-Stack
Lots of nighttime astronomy/astrophotography goodies
Re: Change Focuser Double-Stack Meade/Coronado SolarMax II 9
Post by swisswalter » Thu Oct 30, 2014 6:31 pm
Hi Mark
welcome to that wonderful site. Have fun in the sun. I'm sure stephen can help you.
pedro
Post by pedro » Thu Oct 30, 2014 10:55 pm
Welcome to SolarChat Mark
It is easy to retrofit a better focuser. Consider buying a Feathertouch. It is the best focuser period.
best regards
124Spider
Post by 124Spider » Fri Oct 31, 2014 1:10 am
I have a couple of FT focusers, so I'm well familiar with their products.
My larger question is whether it is fairly easy to retrofit a quality focuser onto the back of a SolarMax II 90, since the blocking filter is integrated into the diagonal (and retrofitting a focuser might make that diagonal useless).
Thanks.
Mark de Regt
DSobserver
Post by DSobserver » Mon Nov 03, 2014 11:19 pm
Not sure to understand, but you have no other solution than to use this diagonal that include an ITF+ the famous BF, whatever the focuser.
Now if you want to replace the helicoidale focuser, you can only unscrew it and connect your feathertouch
124Spider
Post by 124Spider » Sun Mar 01, 2015 1:59 am
Well, I was pondering the best way to get a good focuser, and a BF-30 blocking filter, into my scope. And then one just like mine, with a Feathertouch focuser and BF-30 already installed came up for sale, for a difference that's much less than I would have had to pay to improve mine. So I've bought it. I'm pretty excited as I await its arrival.
Mark de Regt
Post by swisswalter » Sun Mar 01, 2015 7:26 am
Hi Mark
congratulations on the new toy
Post by marktownley » Sun Mar 01, 2015 7:32 am
Very nice! Make sure you post a few pickies of it when it does arrive.
