2 Additions to my 100mm Skywatcher Mod
Solarhound
Post by Solarhound »
I had been looking for a Coronado SM90 II etalon for a while now and was lucky enough to find a gently used one . I made an adapter ring to fit the threads in the end of the retractable dew shield . I just removed the stop ring and installed the etalon so my mod is double stacked now .
As you can omagine this made it difficult to reach both etalons for adjusting and still be able to view the live view and I needed a solution . I was using a Moonlight DC motorized focuser for this mod so I purchased a second motor made a small bracket and mounted it to a couple of existing tapped holes in the Moonlight body . For the drive I used a Dirt Devil vacuum cleaner belt and it works like a charm . My hand controler has 2 channels so this puts focus as well as internal etalon tuning on one remote control . Now I can set up with the external etalon within easy reach and adjust everything easily and maintain a good view of the screen . Here is the Moonlight with the additional motor for etalon tuning , this can also be used in my 150 Istar mod as well .
Here is the scope fully equipped and double stacked
I have only had a couple of opportunities to use this double stacked due to consistent cloud cover , these are some first light double stacked images from November 10 - 14
Has thanked: 20740 times
Been thanked: 10439 times
Re: 2 Additions to my 100mm Skywatcher Mod
Very very nice! That works well! :)
Has thanked: 156 times
Been thanked: 893 times
Post by Valery »
Impressive small setup! Very good contrast and good evenness across FOV.
Has thanked: 8523 times
Been thanked: 8253 times
Nice bit of engineering. Looks great. Nice images too.
Stu
Post by swisswalter »
Hi Mike
congratulations on the mod and the first lights which came out very fine
Has thanked: 174 times
Been thanked: 618 times
Mike,
The external (original) SM filters I found matched well to the internal PST etalon.
I used a 60mm DS system and was very impressed.
I think your results show similar results!
Well done!
Solarhound
Thank you all for the kind comments . It has been the fine modders on this site that have inspired me to do this and of course Stephens open mindedness for providing all of us with a place where mods can be freely discussed .
If there are any Moonlight users out there that are considering remote etalon tuning I would be happy to duplicate the bracket I used to mount the motor and include a belt. The bracket will mount to existing tapped holes in the Moonlight body.
I was very lucky to find the 90mm etalon , it was on a Double stacked SM90 II that was purchased this spring so this is a later model SM II etalon with the Rich View tuning . I was able to convince the seller to sell me just the external . I don't believe that the seller had ever seen what the external could do because I had to move the stop pin 2 holes to bring it fully on band .
Merlin66 you are quite correct this SM 90 II does mate well with the PST etalon . Another piece of good advice came from Mark , I chose to mount the etalon to the dew shield so I coukd easily rotate the etalon , and yes it does make a difference . Thanks Mark and everyone else here who have offered their knowledge and inspiration .
Mike
