What do you think about this CaK combo?
I have come across an optical manufacturer that can provide me with the attached filters for a CaK scope.
I am waiting for the price quote, however, what are your thoughts about the specifications?
- CaK.jpg (69.94 KiB) Viewed 4251 times
- Been thanked: 10488 times
Re: What do you think about this CaK combo?
Way too wide a bandpass to show CaK detail.
Mark, yes I agree, but this will be used in conjunction with Bob's new CaK filter. So the above will only be used as blocking and energy reduction...
So the optical train will be: dichroic mirror, broadband filter, narrowband CaK, camera.
Hi Brett
That may be useful as a prefilter, check out the price against a K-Line filter and please report
Are the filters you have sourced designed for energy rejection or 'visual' use? Even on the context of imaging I am including the tag of 'visual' use.
Walter, I will keep this thread up to date as I get more info and prices.
Mark, the filters above are used as energy rejection. On their own they should not be used for visual. But, if my thinking is correct, when used in conjunction with the Omega CaK filter, it should be safe for visual. The Omega CaK safely reduces down to ND5. For 100% safety for visual use, I would check the transmission of everything carefully. At this stage for visual use I am not 100% sure. However, my aim is to image in CaK anyway.
What i'm getting at Brett is if the filters were originally designed to be used in say laser systems or the like for energy rejection, then optically (through the camera or visually, it does not matter) you may find that they are not optically flat or suffer from internal ghosting which has a detrimental effect. A Baader filter on the other hand are designed for visual use (be it at the eyepiece or with a camera) and as a result is optically flat and the reflections between the different filter elements are controlled.
This is why myself or Walter keep on about using a Baader K line. There is no benefit to using cheaper substitutes.
Ah, okay Mark, I get what you are saying. Yes, the flatness and AR elements are important. However, the manufacturer can machine according my specs. I have told them that it will be for an astromical telescope used for imaging the Sun. So optical flatness should be in the 1/10L area.
I realize of course that the Baader K line is probably the best option at this stage, but it would be nice though if we could get an affordable alternative. Or better for the same price. This is why I asked about Bobs CaK as a blocker in another thread.
- Has thanked: 174 times
- Been thanked: 619 times
I have one of Bob's earlier 40A CaK filters and I'm waiting on his 2A version.
I intend to combine them for CaK imaging.
No additional filtering.
Merlin, will you mind providing me with a link to his earlier 40A version filters?
Just make sure they are designing the optical flatness at 393nmBrett wrote:the manufacturer can machine according my specs. I have told them that it will be for an astromical telescope used for imaging the Sun. So optical flatness should be in the 1/10L area.
I've bought a lot of filters from Bob and also from Baader, at the end of the day you pay your money and take your choice. The Baader filters have always performed considerably better than Bobs, just depends what results you are happy with.Brett wrote:I realize of course that the Baader K line is probably the best option at this stage, but it would be nice though if we could get an affordable alternative. Or better for the same price. This is why I asked about Bobs CaK as a blocker in another thread.
Brett,
Correction - it was an 80A FWHM filter.....
#0391BP010-001
Purchased a couple of years ago from Bob. You'd need to check with him, re current availability.
#0391BP010-001
Thanks Merlin, are you referring to this one:
http://www.ebay.com/itm/Optical-Filter- ... 2331133f62
Yeah, that looks like the one I have.
Brett, I have one of these. You can use it, it will work, but I can categorically tell you there are far better alternatives. These filters are designed for energy rejection not imaging / visual use (like the omega CaK, and probably also the CaH filter, I would speculate based on Walters images). There's a reason why coronado and Lunt use a totally different design of filter than this. if you want it drop me an address via email and i'll post it to you i'm not going to use it.
Hi Brett
Mark is the top CaK modder, belive him. If he is not convinced, don't buy, If Mark and I disagree, don't buy eighter
Mark thank you for your offer. I have sent you a mail with my address. Let me know if you did not get it.
Hi brett, Yes, have received it. I will get the filter in the post to you.
