well here it is sun omega bob caH
highfnum
Re: well here it is sun omega bob caH
Post by highfnum » Mon Jan 26, 2015 12:49 pm
"In any case it is better significantly than K-line."
1) Valery why did you say that ?
I guess Montana and myself are not seeing a great difference from Baader K-Line
2) so your guess is that FWHM some where in 4A-6A area with this filter?(caH)
Post by Valery » Mon Jan 26, 2015 5:36 pm
highfnum wrote:"In any case it is better significantly than K-line."
1. Bacause I see much finer details in 5A Ca H line than at images with K-line 80A (!!!) filter.
The image made by Walter with 6" refractor and 5A Ca H is FUUUUUULL of fine details never imaged with K-line filter.
2. I guess it is about 4A FWHM. The problems are:
a) Poor seeing.
b) Equipment.
c) small scale
highfnum
Post by highfnum » Mon Jan 26, 2015 7:35 pm
Thanks Valery for always answering
sorry to hit you with so many questions
but I value the responses
And its a learning curve
Post by Valery » Mon Jan 26, 2015 7:38 pm
highfnum wrote:Thanks Valery for always answering
Don't worry. You are welcome. I learning here too. Wonderful TOS free solar site!
swisswalter
Post by swisswalter » Mon Jan 26, 2015 8:32 pm
Hi Mark
thank you very much. We have to extend that discussion and it will take time. Another 12 days gone without having had even the chance to capture the disk :( very heavy dark side syndroms, I'm suffering :cry:
highfnum
Post by highfnum » Tue Jan 27, 2015 8:10 pm
VALERY Would stacking another caH filter
3of them would make band more narrow
or does law of diminishing return
set in ?
Post by Valery » Tue Jan 27, 2015 8:43 pm
highfnum wrote:VALERY Would stacking another caH filter
set in ?
I don't think this is a good idea - to stack three Omega filters. Too expensive! Even two filters are too expensive cause it is
possible to buy CaK PST or Lunt B600 for comparable or even less money and have CaK with narrow enough bandpass.
highfnum
Post by highfnum » Sat Jan 31, 2015 10:26 pm
well
I took a few tips from Valery to heart
1) CAh with extra element filter that bob sent me
2) increased FL now F30 for more parallel beam
BUT seeing conditions were horrible - sun looked like I was at bottom of a pool
high winds - i was forced to use my 60mm unitron which is pushing that little baby
none the less if you look close thru the mess
it looks like I have potential for a good image - surface looks more caked
I feel silly posting such a mush image but that is what I have now
swisswalter
Post by swisswalter » Sun Feb 01, 2015 7:43 am
Hi John
bravo you went out despite the horrible seeing conditions. The result however is not convincing me :oops:
highfnum
Post by highfnum » Sun Feb 01, 2015 2:00 pm
Well until weather breaks
I'm taking a break
it is just to fustrating
my answer is I dont know
highfnum
Post by highfnum » Sun Apr 05, 2015 11:21 pm
I have a question about daystar caH
this is mostly geared towards Walter
but anyone may chime in
why was 5.0A chosen instead of 2.0-3.0A like thier caK??
Post by Valery » Mon Apr 06, 2015 4:06 am
highfnum wrote:I have a question about daystar caH
To make it visually usable for those, who can see this light, IMHO.
First thing what you need to improve is the camera.
swisswalter
Post by swisswalter » Mon Apr 06, 2015 6:34 am
Hi John
as simple as that, it was the only filter available. Soon I will receive Bobs CaH and can double stack ;)
highfnum
Post by highfnum » Mon Apr 06, 2015 11:50 am
Walter thanks for taking risk on this one
but I wanted to know why Daystar chose that bandwidth
Post by Valery » Tue Apr 07, 2015 6:59 am
highfnum wrote:Walter thanks for taking risk on this one
I repeat for you: To make it visually usable for those, who can see this light. Ca K is worser for visual than Ca H.
