Transit of Mercury in the Spicule Layer. Phil took this great image with his Quantum 6 Scope, Solar Spectrum etalon and PGR Camera.
White Light Solar Dob?
Dobson described a solar dob made from uncoated mirrors. As anyone used or built one?
Thank you, Here are some references I have collected.
Etalon Article Part I
Etalon Article Part II
Solar Patents of interest
Re: White Light Solar Dob?
Thank you! I had not seen that.
It is nice that it eliminates the obstruction. I wonder if you AR coated the first mirror for H-alpha if you could make an obstruction free mirror based h-alpha scope? In LASERs we have mirrors HR and AR coated for different frequencies simultaneous often.
These uncoated mirror Newtonians are not actually on Dobsonian mounts, but interesting anyhow. Sorry, if I’m a bit out of topic.
I have been planning to build something in this Art Whipple truss rod style using a 200-250 mm mirror (only for imaging). Let’s see…
If I only could get it light enough for my mount. What do you think of the design? The field stop could be a good idea.
http://tinyurl.com/8863u3w
http://tinyurl.com/d52joxr
Viljo
Viljo
If you enclose links with the url button above the editing box they will work with a tilda.
Why not un-aluminize the secondary? Then we get 5% of 5%. That is .25%. Much better. Then we use a ND3 to 4 filter and we are visual. Hmmm....
Yes, I also wondered about his secondary as there is certainly enough light if using an unaluminized one. I haven’t even considered an aluminized secondary.
Interesting that he had no reflection problems due to the white mirror cell.
I wonder if a bit cheaper quality mirrors would do (Whipple used 1/20 λ)?
Viljo
Viljo
