PST Mod Complete
- seti_v2
- Oh, I get it now!
PST Mod Complete
Used Orion 120mm f5 scope. Changed the front collimating lens in the pst etalon assembly to -100fl. zhumell sct focuser and celestron diagonal to attach the pst itf and blocking filter. Also Rosco UV/IR 5.25" and Rosco flame red 5.25" dichroic filters used before the objective for an ERF.
Seeing was absolutely atrocious, worst i've ever seen. Just had to try to see if the setup all worked. I was able to tune and focus. Sorry the images are terrible but they are just proof of concept images. Can't wait for good seeing now.
Frank
PST mod, Orion 120mm F5, Celestron C8
- Has thanked: 20424 times
- Been thanked: 10243 times
Re: PST Mod Complete
Looking a good start! When the weather allows try rotating the etalon assembly you will find there is an optimum position for it relative to the optical axis.
- seti_v2
- Oh, I get it now!
I didnt even think of that. Great suggestion! Im sure that the lenses in the etalon assembly arent perfectfully orthogonal. I will have to do that for sure!
Frank
Another tip to improve things in terms of squaring up, try and get an adapter to allow you to connect the male m56 thread on the end of the skywatchers focuser to the female sct thread in the secondary focuser.
Hi Steve
a good start. Now starts the real modding job
Thanks.. did not know about the rotating trick for the PST mod. It helped a little. Still don't like the banding/sweet spot issue of the pst mod. But for right now it will do until I can afford something more expensive.
Hi Bandazar
more expensive may not mean "more" better
we can improve the results from this setup a bit more yet: Are you using a barlow lens on the nose of the camera? This will reduce the size of the sweetspot. The image above is offband, which, to me, suggests excessive tilt somewhere in the system - probably focuser or connecting joints between the various components...
- seti_v2
- Oh, I get it now!
I am not using a barlow. If it will help than I will definitely put one on. I did find some excessive tilt in the focuser to etalon nosepiece and have corrected that. It was tilted about 3ish degrees. I also need to tweak the etalon position I think a little.
But unfortunately I have about 5 days of rain ahead of me so here's looking for fun in the sun next week!
Frank
You definitely need to be using a barlow! All excessive tilt needs to be reduced to zero for best results...
- Been thanked: 4340 times
Congrats on the new mod and first light.
These mods work very well...just need some fine tuning now. Look forward to seeing more results.
- seti_v2
- Oh, I get it now!
My etalon is placed too far inside focus. My diagonal takes up too much back focus. Does anyone know what the thread size is on the PST blocking filter? I need to figure out how to place them inline instead of threaded on the diagonal.
Even so here are some of the images I got today. I think this is a good start either way!
- sun_152003_g3_ap25 colorize.jpg (83.71 KiB) Viewed 5217 times
- sun_155026_g3_ap187 colorize.jpg (527.84 KiB) Viewed 5217 times
Frank
Hi Frank
that is a good start. to reach the -200 mm you can always add a 2" extension tube. I cant help on the threads of the blockingfilter housing
- Has thanked: 173 times
- Been thanked: 615 times
I think from memory it's a M35 thread.
Good images there, but I don't know if it's the stacking/ processing or optics somewhere, but there seems to be some astigmatism - looks for the extended linear features...those are artifacts.
- seti_v2
- Oh, I get it now!
Just measured the thread. I got M33x0.75 if anyone is curious. I'll have an adapter made up to get the filters inline and ditch the diagonal. It is a really cheap diagonal and may be a cheap prism instead of a dielectric mirror. That may be adding astigma as well.
Keep your fingers crossed!
Frank
Hi Frank
I will, good luck
I will, good luck
- seti_v2
- Oh, I get it now!
Well i bored out a 2 to 1.25 inch adapter to fit the itf and blocking filter. So everything is inline now. And i checked and my diagonal is definently a prism and may have been adding a little astigmatism.
Now i just need clear skies and i should be set!
Frank
- seti_v2
- Oh, I get it now!
Got rid of the diagonal and got the itf and blocking filter inline. Brief sun and poor seeing but my imaging is getting better.
- AR12305.jpg (429.21 KiB) Viewed 5078 times
Frank
Hi Frank
you move in the right direction
