Setup with HaT
fjabet
Setup with HaT
Post by fjabet » Mon Mar 23, 2015 8:49 am
Hello,
I was asked by PM what was the setup(s) I use with the HaT, so here it is with some pictures. Note that this is work in progress, but it will always be.
The big picture :
You can recognized the HaT that is based upon a C8 Edge HD. I may move to a C11 this year.
On the Hat stands the Solar Scintillation Monitor probe. The probe needs be to as close as possible to the telescope entrance to match the seeing that actually interest us. Then comes the telecentric amplifier. This comes with the HaT and brings the F/D to 27.5, and deliver a real telecentric output with field angle lower than 10E-2° at 656.28nm. It has really been designed for Ha.
It is possible to increase the F/D by adding a spacer between the HaT and the telecentric. This is possible up to 50mm.
Then I use three different combinaisons of filters : Daystar, PST and Lunt
The telecentric offers a tiltable cell at is entrance. This is the place I use for prefiltering as the sun's size here is only 19mm. The free aperture of the telecentric first lens is 23mm.
Here is a view of a new telecentric empty from its optics :
PST setup : the BF15 and a KG3 IR/UV block from Beloptik are located at the telecentric input.
The tiltable cell is used a bit to get rid a of small reflection between the BF15 and the first lens of the first telecentric group. Then comes the telecentric. The sun's size at the telecentric exit is 50mm. The free aperture of the telecentric exit lens is 48mm but it is also limited by the SCT thread to 44mm. So virtually we could have the full sun visible, but that is not the goal of this telescope obviously.
Then comes the PST without its lenses. I use short adaptors with SCT threads all along. SCT thread is nice as it has a larger aperture than T2, and the threads are much more robust than small 0,75 T2 threads.
All adaptors, including telecentric parts, are made on purpose by Skymeca in France and are 3mm wall thick for a maximum stiffness as tilts have a devastating effect on etalons. Everythink is screwed between the HaT and the etalon.
Then you can use whatever you need. Here there is a tilt ring to get rid of interferences on the CMOS sensor, an helicoidal focuser I don't use all the time, and a Basler acA1920-155um embeding an IMX174.
Lunt : The lunt setup is the same. I just add a Coronado RC that get rid of a small reflection somewhere.
Daystar : I use the Daystar mainly for visual as its 32mm etalon can cover any eyepiece, even a 21mm Ethos. It is screwed on the telecentric using a T2/SCT adaptor as the Quantum front adaptor is T2. When I use any combinaison, usually a Binovue with two 35mm Eudiascopic. I may add the 1,5A Omega filter that brings a nice added value.
Derek Klepp
Re: Setup with HaT
Post by Derek Klepp » Mon Mar 23, 2015 10:26 am
Thanks it's always good to see what others are doing
cheers Derek
Re: Setup with HaT
Post by swisswalter » Mon Mar 23, 2015 4:51 pm
Hi Frédéric
thank you very much for explaining your set ups
Re: Setup with HaT
Post by marktownley » Mon Mar 23, 2015 5:29 pm
What a fine scope and setup!
Is there any reason you have the blocker, and then the UV/IR KG3, rather than putting them the other way around as putting the KG3 first would reduce the thermal load on the BF15.
fjabet
Re: Setup with HaT
Post by fjabet » Wed Mar 25, 2015 4:08 pm
marktownley wrote:What a fine scope and setup!
Yes : the KG3 is an absoption filter ! And the BF just reflect almost everything.
fjabet
Re: Setup with HaT
Post by fjabet » Wed Mar 25, 2015 4:09 pm
Neo wrote:Impressive toys!
About using the PST etalon, is there a need for the telecentric device as the PST is originally layed out for a f/10 system?
The field is homogeneous when used in telecentric mode. This is for HR, not to see the whole sun :)
The FoV is about 1/8th of the sun, that's quite enough to enjoy in visual observation.
Re: Setup with HaT
Post by marktownley » Wed Mar 25, 2015 8:30 pm
Doh! That's fairly obvious now I think about it :lol:
fjabet
Re: Setup with HaT
Post by fjabet » Wed Mar 25, 2015 8:39 pm
Neo wrote:Thank you, I guess. I don't see how that answers my question but it's okay.
It's beyond my budget anyway.
I try again, my fault :)
At F/10 with its collimating lens, the PST etalon would deliver only a very small sweet HA spot (Jacquinot effect) due to the 2m FL. As this system is made for high resolution, and that requires a good FL, so it makes much more sense to use it with a telecentric amplifier that uses 100% of the PST 20mm etalon.
Nevertheless it works with a PST and its lenses, but you need to have a rather small sensor.
Bill Edelen
Re: Setup with HaT
Post by Bill Edelen » Fri Mar 27, 2015 1:44 pm
thanks for showing...
Re: Setup with HaT
Post by marktownley » Mon Dec 21, 2015 9:05 pm
Hi Frederic, I have a question; is the back of the telecentric unit a male SCT thread?
fjabet
Re: Setup with HaT
Post by fjabet » Fri Jan 08, 2016 5:57 pm
Yes Mark it is !
