played with 2 omega cak and skybender to tilt
highfnum
Post by highfnum » Mon Mar 30, 2015 9:51 pm
I placed one filter on bottom and one filter in tilter
I used a WO 66mm SD
on screen tilting filter changes brightness
seeing was bad but I got this interesting result
will keep posting as I try different options
its been a horrible season im just getting back into this
highfnum
Re: played with 2 omega cak and skybender to tilt
Post by highfnum » Tue Mar 31, 2015 1:01 am
with too much of a tilt you get double image at end but shows area of interest fading out
I did not note exact angles
highfnum
Post by highfnum » Tue Mar 31, 2015 1:05 am
another tilt angle
I think this(skybender) can be useful to fine tune into a specific area
there could be a price in that total area may not be 100% uniform across entire field due to internal reflections
Post by swisswalter » Tue Mar 31, 2015 4:12 am
Hi John
interesting results. With 66 mm you should get crackling pics even in bad seeing conditions
Post by marktownley » Tue Mar 31, 2015 6:32 am
Interesting results, but the lines in image one and two suggest astigmatism to me. What camera are you using?
