modification helioscope Scopium in Ha
JF Roudier
Post by JF Roudier » Sun Apr 05, 2015 4:04 pm
Hello, we are currently testing a Scopium helioscope whose prism Ha was treated by the MCM company in France. This material will be presented to the ROS 2015 (dating Solar Observers) Serbannes on 20 and 21 June Meanwhile some pictures of this lens here: http://www.astrosurf.com/jiaifer/pagescopiummod.htm
Thank you, good heavens,
Jef
Re: modification helioscope Scopium in Ha
Post by marktownley » Sun Apr 05, 2015 4:15 pm
An interesting concept! Keep us updated as to how you get on :)
Post by swisswalter » Mon Apr 06, 2015 6:43 am
Hi Jef
thanks for sharing. The Scopium has another advantage, it does not need as much in travel as a herschel wedge
zorgdotnl
Post by zorgdotnl » Wed Apr 08, 2015 9:11 am
That's very interesting. It looks that it could be used as a secondary mirror on a Newton too with an adapted holder. Do you think that the coating will tend to age?
JF Roudier
Post by JF Roudier » Wed Apr 08, 2015 5:48 pm
Hello, thank you for your comments.
I do not master the English language is an automatic translation ...
For the behavior in time of the deposit, we believe it holds very well. It's a bit the same as the deposit on SC Ayrilab proposed by the company.
Currently operating with an FP PST is not very good, there is a visible reflection of the objective of the telescope used.
The treatment can be done on a secondary Newton, tests are also underway.
Best Regards,
Jef
Post by swisswalter » Wed Apr 08, 2015 5:51 pm
Hi Jef
thanks for the update
