Help on Decontacted Etalon
Geremia Forino
Post by Geremia Forino » Wed Apr 15, 2015 5:52 pm
Hello to all,
i need your help on this LS35T decontacted etalon, the spacer seem to be well attached to one of the two surfaces.My question is, what can I use to clean them (spacer and etalon) and what kind of glue should be used, also, and this is the most important, I need any kind of recommendation that can take me to the success of this repair
:bow
if you need more pictures, just ask
Re: Help on Decontacted Etalon
Post by swisswalter » Wed Apr 15, 2015 7:17 pm
Hi Geremia
I'm sorry for you. Was that an accident ? Have you contacted LUNT ? Where are you living ?
Post by marktownley » Wed Apr 15, 2015 8:02 pm
You could try Oliver at Beloptik, he recontacts etalons...
Geremia Forino
Post by Geremia Forino » Wed Apr 15, 2015 9:27 pm
Hello Walter, it is bomm, fallen on the ground, I'm living at south of Italy, Naples. I read about that you're an expert on this :D :D :D
@marktownley
I would like to see if I can save that amount, 250 euro for us Italians are a lot of pennies
Post by Merlin66 » Wed Apr 15, 2015 11:36 pm
Geremia,
I assume you have two of the small spacers still in place on one etalon plate and the other spacer still on the second etalon plate?????
There's no glue involved. It requires full "optical" contact to be made between the spacers and the etalon plates.
The optical surfaces must be clean - really really clean - chemical isopropyl alcohol or chemical acetone can be used.
When the surfaces/ spacers are perfectly clean they can be laid back against each other - note the alignment marks in your photo.
Use a flat firm base with a layer of tissue...
Using a razor blade, dip it in distilled water and very gently use the sharp edge to place a LITTLE onto the spacers by easing the razor blade into the side of the gap. Not too much! A VERY small amount is required to wet the spacer surface.
Press the plates together - if you're very very lucky you'll see the spacers make good contact.... Otherwise, gently tap the top etalon plate above the spacer(s) with the end of a plastic rod (to prevent damage), if everything goes to plan they spacers as viewed from the front, should "disappear" as they make optical contact....
Let the assembly dry out completely then re-assemble in the scope.
I make no assurances to you, this is done absolutely at your own risk....
Geremia Forino
Post by Geremia Forino » Thu Apr 16, 2015 12:09 am
Thanks Merlin, i will try tomorrow early in the morning why today, I had much coffee :D
Post by swisswalter » Thu Apr 16, 2015 4:56 am
Hi Geremia
good luck on the fix. You could always contact Oliver at beloptik
fjabet
Post by fjabet » Thu Apr 16, 2015 7:57 am
I did it a couple of times on Coronado. As Merlin mentioned just clean up thoroughtly the spacers with aceton (better than Alcohol), align, and firmly recontact until you hear the snap sound of the molecular bonding.
BUT if the spacers are surrounded by glass little pieces as I saw on the couple of Lunt etalon I had, it may be very very difficult.
Coronado's are very clean when compared with Lunts.
Here is a of the shelves Lunt LS50Fha with very poor molecular bonding and glass shreds sourrounding them :evil:
Geremia Forino
Post by Geremia Forino » Thu Apr 16, 2015 3:40 pm
Game Over, I lost the spacers :oops:
everything was ready, my desk looked like a nuclear laboratory, acetone, distilled water, razor blade and those of latex, but.....missing the most 'important, SPACERS :mad: :mad: :mad:
now :?:
Post by swisswalter » Fri Apr 17, 2015 4:50 am
Hi Geremia
ohhhhh noooooooooooo.
Post by marktownley » Fri Apr 17, 2015 5:39 am
A claim on your insurance?
Geremia Forino
Post by Geremia Forino » Fri Apr 17, 2015 9:21 am
I have everything ready to be shipped to Beloptik, I think this is the best solution,
thanks anyway for your valuable advice
Geremia
Post by swisswalter » Sat Apr 18, 2015 5:35 am
Hi Geremia
good luck
Geremia Forino
Post by Geremia Forino » Sat Apr 18, 2015 11:06 am
Thanks Walter
Bob Yoesle
Post by Bob Yoesle » Sun Apr 19, 2015 3:51 pm
I don't know if Oliver can supply the spacers independent of what came with the filter. Without all the spacers you might be looking at having to get a new etalon. Or you might have to send it back to Lunt tho have all the spacers replaced and re-contacted. Spacer thickness and uniformity requires that they all come from the same area of the spacer "blank."
Geremia Forino
Post by Geremia Forino » Sun Apr 19, 2015 6:08 pm
This was my concern to, but, is it so difficult to find a something to substitute mica ?
very thin and pure microscope Slides ?
Bob Yoesle
Post by Bob Yoesle » Mon Apr 20, 2015 2:20 am
Etalon spacers need to be made from a very low expansion material such as pure fused silica, quartz, Zerodur, etc. Then they need to be polished flat to about 100 lambda on both sides, with no wedge. The thickness needs to be controlled based on the design of the filter and its coatings to achieve the proper gap spacing. Then they need to be broken off the same area of the finished spacer disc to ensure etalon plate parallelism and uniformity...
Geremia Forino
Post by Geremia Forino » Mon Apr 20, 2015 7:25 am
Bob, thanks for your clarification
Geremia Forino
Post by Geremia Forino » Mon Apr 20, 2015 4:17 pm
Good good news from Oliver beloptik,
seems that he is able to fix it even with a lost spacer, hope to show you a nice first light as soon as I get it back
Post by swisswalter » Tue Apr 21, 2015 4:22 am
Hi Geremia
great news. I'm happy for you
Post by marktownley » Tue Apr 21, 2015 5:23 am
Good stuff, let us know how first light goes...
Geremia Forino
Post by Geremia Forino » Sat May 16, 2015 11:17 pm
The miracles as been done by Oliver from beloptik :D ,just with the remaining 3 spacers.
now the next steep, dual stack it with the Daystar 0.5A. Today i received from my friend CNC Lathe Operator, the box to fit the ls35. On the front is a 140mm ERF and Powermate 4X that reach the f/30 on a TEC140, now I have just to wait a decent ray of sun ;)
Any suggestion or recommendation ?
Post by swisswalter » Sun May 17, 2015 4:18 am
Hi Geremia
great news, looks very, very clean that recontacted etalon. That double stack setup looks fine too. I would have used a TZ4 instead of a powermate. Looking forward to the first light
Post by marktownley » Sun May 17, 2015 7:03 am
Good news! That setup will work well :)
