Thinking about a large 127mm PST mod...
Need an ERF, the Baader D-ERF is obviously the best way to go, but expensive and is it overkill?
With the Solarmax 60 for example, the main unit has no external ERF just an internal hot mirror. The 60mm DS unit for it uses a colored filter. If the single etalon unit only needs a hot mirror why did they need a color filter on the external etalon unit?
I realize that I could use a smaller D-ERF inside the tube to decrease the cost but I'd like keep it outside for easy access. Also does having the ERF inside or outside change the optics characteristics in anyway?
I bought a hot mirror on eBay to check out,
http://www.ebay.com/itm/DICHROIC-HEAT-F ... 27a55ff315
Maybe it's not a hot mirror, to test I put it in front of a lens pointing at the sun thinking it would curb the amount of heat the lens made but didn't seem to have any effect (tried both sides 0 and 45degreae angle), any idea why not?
Would standard red color filter would well enough, if so anyone have a good source for them? Thanks.
ERFs for large aperatures D-ERF, colored glass filter, or hot mirror??
- Been thanked: 10248 times
Re: ERFs for large aperatures D-ERF, colored glass filter, or hot mirror??
I don't think the Baader D-ERF is overkill, infact I think is the standard for ERFs. problem with alternatives for ERFs is that optically they are not very flat...
Yeah.. probably half the reason they cost so much.
What about the Lunt ERF's? They are a lot cheaper are they just as good? Anyone have a spec or plot on them?
Thanks
Thanks
They're half the thickness and pretty much half the optical flatness the baaders are. Much better to save up and get the baader...
Used C-ERF sounds like a plan...I'll look for a used one at the Lunt price :cheer:
However on the Lunt ERF, I understand they are not as good, but good enough for Lunt right, so seems like they should be just fine for us....
Well, I use a Lunt 75mm ERF and it is excellent! What's the point producing them anyway if they aren't up to the job??
Not saying they're not up to the job, just the Baaders are just optically better
Right, they are, I just can't see the difference though the scope. And the idea making PST mods originally is for saving money I would say. A 75mm Baader will set you back 255 euro and free aperture maybe 70mm?? A 80mm Lunt 199 euro and free aperture is 75mm.
I agree, you can't see the difference through the scope. However put a 1/4 wave ERF on a scope such as an AP or a TEC and compare it to a 1/10th wave ERF with a decent CCD and I bet in good seeing there is a difference
- Has thanked: 173 times
- Been thanked: 615 times
Langleif,
Caution:
""the idea making PST mods originally is for saving money""
This shouldn't be the motivator...modding PST's can and is expensive!
You'll only do it once (right?) so make the best decisions you can...
To me, the optimum "mod" is a D-ERF on a 100mm f10 OTA and a BF10 blocking filter.
What you achieve is not a Lunt100 or a SM90...it's a good modded PST Ha scope.
Caution:
Sorry mate...
I do enjoy the 102mm modded PST for visual....the 0.7A is OK for me...
Imaging, well I would use the single or double stacked SM60 on the ED80.
