a demo with skybender
highfnum
Post by highfnum » Fri May 01, 2015 4:49 pm
I normally use skybender with omega Ha filter in mode similar to thousand oaks prom viewer
however dynamic range is so huge that my camera just don't do well in capture (visually its great)
so
I came up with an analogy of using same filter as a "poor mans double stack" with lunt 60
I set lunt tilt once and then just used skybender to tilt omega filter only
here is pic of set up with camera
highfnum
Re: a demo with skybender
Post by highfnum » Fri May 01, 2015 4:51 pm
look close you can see proms come in and out of view
im using skybender to tilt omega filter only
there is some movement of sun in field do to hand touching
Post by swisswalter » Sat May 02, 2015 6:44 am
Hi John
yes the proms are obvious
Post by marktownley » Sat May 02, 2015 7:07 am
good result with the omega and skybender. i use a skybender with my Cak setup, they're very good.
