PST etalon spacer
PST etalon spacer
Post by swisswalter » Fri May 15, 2015 4:16 pm
I read some where about the need of having to know the thickness of the spacers used on an etalon. As I have only one broken etalon of a Ha PST I measured the two spacers left on it.
using the mikroscope I find ~200 µm, using a JKA-feintaster I get an average of 204 µm
hope that helps a little
Re: PST etalon spacer
Post by marktownley » Fri May 15, 2015 7:36 pm
Informative as always Walter, thanks :)
Post by Valery » Sat May 16, 2015 1:00 am
Hi Walter,
Thank you very much for such an information. Very important!
Valery.
Post by swisswalter » Sat May 16, 2015 5:49 am
Hi Mark, Hi VAlery
thank you very much, you are welcome. It is always interesting to look deeper into those things
