Coronado diagonal ERF
Moriniboy
Post by Moriniboy » Fri May 15, 2015 9:19 pm
Just stripped the ERF out of the diagonal and as expected its failed so I have been checking out replacements from Maier
The Maier replacement does not have a glass element in front like the Coronado original one does (see photo), will this be a problem or was the glass element just to protect the ERF from prying fingers and damage?
Hoping for clear skies.....lol
Re: Coronado diagonal ERF
Post by swisswalter » Sat May 16, 2015 5:58 am
Hi Nigel
a fine closeup of that ERF stack. You would have to run an UV/VIS spectrum in order to find out whitch part regulates which spectrum
Post by marktownley » Sat May 16, 2015 8:56 pm
The maier will work just fine as a replacement.
