FT focuser motorization with Orion Accufocus
Marco Michelassi
Post by Marco Michelassi » Tue Jun 16, 2015 5:41 pm
Hi all !
I'd like to show you my personal,home made motorization
of the FT focuser equipping my Lunt 100 :
http://imageshack.com/a/img661/5885/9ZX5o6.jpg
http://imageshack.com/a/img910/3129/sVJoBZ.jpg
http://imageshack.com/a/img537/6692/rfkFZy.jpg
http://imageshack.com/a/img908/6545/F2R0RO.jpg
The motorization is a cheap Orion Accufocus,
as far as I know the cheapest on the market,at least in my
tax-afflicted country.
Unfortunately it couldn't be adapted with the provided hardware :
not so bad,I made it by myself with simple aluminium and some screws,
in such a way that leaves the undeniable advantage of rotating the focuser at will.
The plastic adapter,coming with the Accufocus,allows me to lock/unlock the motor,
so that I can switch between visual and imaging use in just few seconds,
tightening/loosening the friction as well.
The motorization itself is now connected to a FCUSB adapter,via an RJ cable made by myself,
with a cheap mono jack.
That's it,maybe the most useful realization I've bben making for my scope !
OTA : Lunt 100 DS BF 3400
Mount : Skywatcher Az-Eq6 custom
ZWO-ASI174MM
Visual setup includes Baader Mark V Binoviewer-Zeiss prism and several pairs of Orthos
Re: FT focuser motorization with Orion Accufocus
Post by marktownley » Tue Jun 16, 2015 8:36 pm
Cool mod!
Post by swisswalter » Wed Jun 17, 2015 3:57 am
Hi Marco
that is a great adaption
Rybak
Post by Rybak » Wed Jun 17, 2015 8:00 am
Good job Marco! I use just the same motorfocus of Sky Watcher on Megrez 90. Cheapest and simplest solution.
Aleksey
Lunt LS100THa, Coronado SolarMax II 90 Filter + BF 15 on WO Megrez 90, PST + SW 1025 mod, Quark + SW150/750 in test mode
_Zakalwe
Post by _Zakalwe » Thu Jun 18, 2015 11:52 am
Ditto! Great little motors.
I use one on a Baader Steeltrack. It's controlled with a Hitec Astro controoler, which gives me PC control. The baader come with the correct tooth profile machined into the focus know for the cambelt.
Marco Michelassi
Post by Marco Michelassi » Thu Jun 18, 2015 4:27 pm
Well done too !
Great focuser the steel track,apart from the teflon grains.
And what's more,you've got a profitable motorizatio at a little price,
especially if we consider that the Baader motorization fro the steeltrack is,IMHO,
absolutely overpriced.
One question :
You own a Lunt 60,isn't it ?
Was it a standar crayford equipped one or the FT version P-Tuned?
ZWO-ASI174MM
_Zakalwe
Post by _Zakalwe » Fri Jun 19, 2015 8:56 am
Marco Michelassi wrote:Well done too !
One question :
I was the standard Crayford, which I think is nowhere near good quality enough for a scope of this price tag. However, the FT version, lovely as it may be, is overkill. It add 25% to the price and for an imager like me, it will never be asked to carry the load that it is capable of. The Baader Steeltrack Newtonian focuser was £200, and is far superior to the standard GSO Crayford. Nearly as good as a Moonlite and a lot more cost effective than the FT.
