my "Sunlux" PST mod
astrohardy
Oh, I get it now!
Oh, I get it now!
my "Sunlux" PST mod
Post by astrohardy » Sun Jun 28, 2015 7:18 am
Just saw this forum and just needed to register.
Completed a PST-mod some time ago, based on a 70/700mm "Skylux" refractor. Some years ago these telescope were offered here in Germany by a discounter (Lidl). They normally have decent optics but a lousy 1.25" focuser, and used ones are offered frequently on Ebay, flea markets and elsewhere. So Marcus Ettling from my astronomy club came up with the idea to use it for a PST mod, and he actually made a company produce the adapters on demand. So I just had to look out for a used ERF, order the adapter, cut the tube that it would be homofocal with a standard PST.
Works very nicely, and the resolution is much better than a standard PST. Focusing is done with the PST focuser. I use a DMK41 camera. In order to get the focus with a PST I need a barlow. With the mod I need some 13-15 videos for a full disk mosaik, which is easy to do. Here are some examples from the first year of operation.
full resolution
As the PSTs generally suffer from brightness gradients across the field of view, one essential improvement was to routinely use flats, which I create by massively defocusing the telescope. Autostakkert can create a master flat from a video and also does the correction while stacking.
Currently thinking about modifying a 127mm refractor, which I am mainly using for white light imaging.
Hartwig
Re: my "Sunlux" PST mod
Post by marktownley » Sun Jun 28, 2015 8:55 am
Welcome to the forum Hartwig! That's a great mod that is producing some fantastic results. I like how you have your mount head fixed to the balcony too; very good!
GUS
Post by GUS » Sun Jun 28, 2015 9:10 am
Welcome to the site Hartwig. Fantastic mod and images.
Derek Klepp
Post by Derek Klepp » Mon Jun 29, 2015 10:56 am
A very successful mod
Vicchio
Post by Vicchio » Sat Dec 10, 2016 7:58 am
Very very nice solution!
What do you think about a "Sunlux" without the frontal ERF , on a stage 1 PST mod, with a second generation PST that have its internal Erf without filter on the original 40mm lens?
Post by marktownley » Mon Dec 12, 2016 11:35 am
I think you would need some kind of filtration to keep the heat off the etalon and stop it potentially causing the tuning to drift because of the heat.
