Internal DERF ina Schmidt Cassegrain
sulcis2000
Post by sulcis2000 » Wed Jul 01, 2015 9:49 pm
What do you think about an internal ERF installed inside a SCT ota in front of the secondary mirror?
Could it be a good idea?
Ale
Alessandro Bianconi
________________
Celestron C14HD Edge
Refractor 228 F8 Truss Tube with D-ERF 110mm
A&M Refractor APO LZOS 130 F6
Daystar Quark Chromosphere version
Daystar Quark Calcium H
Starizona Hypestar
10 Micron GM2000HPS II Mount
Ioptron CEM120 Mount
ZWO ASI294MC Pro
ZWO ASI178M Cooled
ZWO ASI174M
DSobserver
Re: Internal DERF ina Schmidt Cassegrain
Post by DSobserver » Wed Jul 01, 2015 10:15 pm
Post by marktownley » Thu Jul 02, 2015 5:36 am
Who knows Ale, uncharted territory. However, you are an experienced modder, if you are happy to risk the scope trying it then why not ;)
mdwmark
Post by mdwmark » Thu Jul 02, 2015 7:57 am
If you where going to try this. You are going to need a really good ERF 1/10wave or better on transmission. You would be going through the ERF twice. I would tilt it so the reflection would not go straight back to the main mirror. You might want to cut a fan or two to pull the hot air out of the tube also.
Good luck if you try it.
Mark W.
Post by marktownley » Thu Jul 02, 2015 8:06 am
yes, reflections indeed. Maybe a circular polariser or 1/4 waveplate needed then too?
