my chromosphere/prom viewer
highfnum
Post by highfnum » Sat Sep 19, 2015 6:30 pm
60mm Unitron objective with 2X barlow, Lunt ERF
skybender filter tilter qnd omega filter
similar to HAU from thousand oaks
skybender gives good smooth tilt action
DSobserver
Re: my chromosphere/prom viewer
Post by DSobserver » Sun Sep 20, 2015 8:34 am
wich filter from omega did you place?
Post by marktownley » Sun Sep 20, 2015 9:19 am
Looks good! Any pictures taken with it or just visual?
highfnum
Post by highfnum » Sun Sep 20, 2015 11:46 am
highfnum
Post by highfnum » Sun Sep 20, 2015 11:48 am
geared for visual
ill try pics
Brett
Post by Brett » Mon Sep 21, 2015 4:44 pm
Which of the two filter links you mentioned did you use?
highfnum
Post by highfnum » Mon Sep 21, 2015 10:04 pm
i have both
but cheaper one works just as well
zorgdotnl
Post by zorgdotnl » Tue Sep 22, 2015 5:56 am
Great setup!!! So you have the double stack with one filter in double pass too? not trisky with ghosts?
DSobserver
Post by DSobserver » Thu Oct 15, 2015 4:00 pm
no more test or news?
highfnum
Post by highfnum » Sun Oct 18, 2015 5:41 pm
not yet -- yes and tilting can lead to a ghost
DSobserver
Post by DSobserver » Sat Feb 27, 2016 12:34 pm
no new test?
By the way how did you adapt this 25mm filter in our 1.25" eyepiece?
highfnum
Post by highfnum » Sun Feb 28, 2016 1:53 am
filter is in screw in filter ring
ring screws into tilting unit
DSobserver
Post by DSobserver » Sun Feb 28, 2016 7:49 am
You mean that 28mm filter holder can be screw in 31.75mm filter ring?
highfnum
Post by highfnum » Mon Feb 29, 2016 12:00 am
picture worth more than words
filter in and out of skybender tilter
highfnum
out
DSobserver
Post by DSobserver » Mon Feb 29, 2016 10:03 pm
PM send
