H-Alpha Double-Refractor 120 / 135 / 150mm Aperture ?
- Solar-Cologne
- Been thanked: 11 times
Hello,
I am a new ;Member here and my Name is Achim, from Cologne/Germany.
Sorry, but my english is not so good, i hope, i learn a little bit here in SolarChat
I am an Hobby-Astronomer since 6 Years started with an old TASCO Newtonian 114/900....
By the Time, i learn it to love our Sun.
I found the way in this Chat, because i want to have worldwide Connections with H-Alpha-Telescope Users.
Why ?
I am inquisitive in H-Alpha especially selfmade Telescopes.
At assemblies Scopes, i use two Coronado-PST, and a third PST-Etalon in an Aluminium case, mecanical Tuning, T-2 Adaption with an Baader TZ-4 Telezentrik.
By the Time i made a selfmade Scope with PST-Conversation and one with Lunt60-Conversation.
My last Step is an old Meade ED-178 with f=30, Doublestack. Its in work.
My Dream is an H-Alpha Double-Refractor with two C-ERF and min. 120mm Diameter or greater, without Frontetalons, at the end the Matsumoto Two-Mirror-System.
Is there anybody, using a Binocularscope like this ?
Or has somebody the same dream...?
PS:
My best H-Alpha Friends are Oliver Smie / http://beloptik.de/ and Wolfgang Lille / http://sonnenfernrohr.de/
I am lucky to know them both.
sunny Greetings
Achim
Why ?
PS:
sunny Greetings
Achim
- Been thanked: 171 times
Re: H-Alpha Double-Refractor ?
There will be someone here with knowledge Achim.I am still learning just basic modding.
Don't forget to post some pictures of your scopes.
- Solar-Cologne
Hello Derek,
oh my, i have a lot of Sun-Scopes....
I dont wont to make a mistake here in Solarchat.
In which Board i can post my Pictures ?
sunny Greetings
Achim
sunny Greetings
Achim
- Has thanked: 20908 times
- Been thanked: 10562 times
Hi Achim, welcome to the forum! You certainly have a lot of scope setups there. Never tried the binocular scopes like you talk about, but certainly sounds interesting. You can post your pictures in any of the boards here.
- Solar-Cologne
My Plan is to build a H-Alpha Binoscope with my self made 6" f8 FH-Binoscope with Matsumoto Mirror-System, with the build in Pentax 6x7 Helicoid-Focussers to adjust the Eye-Diameter.
I build it, because i like the big Fujinon 150 Binoculars.
My Scope is better than the Fujinon, because i can up to 300x ....
The Fujinon has a shorter focalratio and the wider Field....ok.
This Refractors are the older Bresser types from the Year 2000, not adjustable Lenses.
I have two Al Jaegers 6" f8 brand new Lenses.
now, i will make the Adapters for the Jaegers, they are 10 Times better than the Bresser, like an Semi-Apo....wouw.
I have two W.Lille C-ERF, one 135mm and the other 160mm and two PSTs,
I need only five Adapters and a second Zeiss-Abbe-Barlow to make a self-made 120mm H-Alpha-Binoscope.
sunny Greetings
Achim
sunny Greetings
Achim
Wow, that is a cool setup!
- Has thanked: 65 times
- Been thanked: 4441 times
Welcome Achim...
That bino scope is rather unique...it will be interesting to follow this project as it develops.
I am envious with the green background and ground everywhere there. This is the nicest environment for a good solar seeing which is the key in this hobby.
Valery.
Valery.
- Has thanked: 541 times
- Been thanked: 811 times
Hi Achim,
Impressive, but I'm not sure it would be the best approach.
1. OTA alignment seems like it might be a problem in order to get coincident visual fields.
2. For the twin scope you will need two etalons. Internal collimated etalons with the PST collimator-etalon-refocus lenses would be very complex with the Matsumoto mirror system and Pentax focusers. Using telecentric based filters (DayStar, Solar Spectrum) will give you a huge EFL, making OTA and internal optical alignment issues even more critical.
3. There are no commercially available front etalons over 100 mm in diameter. They are expensive, and you would need two. It would be better to use them double stacked on a single OTA with a binoviewer.
I certainly don't want to discourage you from trying, but in the end, you would probably be better off using a single 120 mm objective with a LS 60 or (better) LS 80 internal etalon system, with the appropriate DSII for double stacking if desired, and using a binoviewer.
Just my 2 cents worth...
- Solar-Cologne
Hello sun-friends,
Thanks for interesting this project.
Bob,
My thoughts to built this scope, I discussed with Oliver Smie.
Our first plan was to use the brand new Daystar-Quarks.....fine, a good idea.
We think, its a very good h-alpha-component, and its the right time when started in the market.
We speak with M.Ludes APM/Telescopes, if the next batch arrive here in Germany we want to test them all and i get two of the best one......
But whats happend.....they all are, to put it mildly, not so good..... we were disappointed
What we can do ?
Then it occurred to me, to use my two Coronado-PSTs.
All components are available, its cost me no money, only the five adapters.....
At next time i will test it, with two friends, with a single refractor, to put the etalon between the tube and the Matsumotos and the blockingfilter with barlow and eyepiece on the top
Oliver said, it will work.....maybe later, we will see...
About the biggest Frontetalons:
Today, i ask Wolfgang Lille, he knows all about H-Alpha components.
Coronado has only built 5 pieces of a 140mm fronetalon in about the Year 2000 or earlier. It costs about 32.000,- DM, old German D-Mark, 16.000,- €.
But when they build it today, i think it costs 32.000,-€.
One User in Germany has two of them....not me....
sunny Greetings
Achim
Bob,
What we can do ?
sunny Greetings
Achim
- Solar-Cologne
Hello Sunny Girls and Boys,
After a long period of Astro-abstinence........becaus i have more Hobbys......Highend HiFi.......and Motorcycles.......and my best Astrofriend Sascha, he was an H-Alpha Enthusiast too and my Parents died.
Now i will new started the 120mm H-Alpha Doublerefraktor Projekt, because I'm a purely visual H-Alpha observer.
I got the latest ones of Matsumoto EMS U-L with silver coated Mirrors....97,5 % Reflction and 148mm Lightpath.
http://ems-bino.com/ems-product-line-english/
The average reflectivity through the visible spectrum per one mirror is as high as 98.5 percent, and 97 percent of the incoming light is secured even after 2 times of reflections.
I have two very good original C-ERFs 135mm and 160mm
Two Skywatcher 6" f8 Refraktors, very good for H-Alpha.
Two Coronado PSTs
Two Matsumoto EMS U-L
Now, i need some Adapters to built this Binoscope......later.
Yesterday i watched the sun for the first time in this Year 2020 with my single 120mm 6" f10 PST.
sunny Greetings
Achim
Two Coronado PSTs
sunny Greetings
Achim
Last edited by Solar-Cologne on Thu Mar 26, 2020 10:25 pm, edited 3 times in total.
Looks good Achim. What happended to the 2 scopes from earlier in the post?
- Solar-Cologne
Good morning Mark,
The 2 telescopes are still available.......I said it in the last post
- robert
- Has thanked: 4 times
- Been thanked: 1275 times
Let us know how you get on!
Robert
Robert
- Solar-Cologne
I have now also received a second Zeiss-Abbe Barlow at a ridiculously low price.
Sometimes i will use a 0,5 x Reducer 1-1/4".
W. Lille now produces the necessary adapters for me.
Waiting.......
sunny Greetings from Cologne
Achim
Waiting.......
Achim
- Solar-Cologne
- Solar-Cologne
I stupid ...... enlightenment came to me this morning.
I have a one-off production of a PST etalon, built into a red anodized aluminum housing, which can be tilted from the outside
T-2 adaptation and mounted afocal original PST lens system, removable to use a real telecentric.
So screwed the afocal lens system back in and looked into my adapter box ......
Hooray, everything is there.
I first fix the PST block filter unit without PST-ERF with silicone or similar material to test.
Now I'm curious to see if I come into focus .......
sunny Greetings
Achim
sunny Greetings
Achim
- Solar-Cologne
Today I was able to test.
A friend helped me with that.
One of the two Skywatcher 6 "f8 refractors with 135 C-ERF and the adapted PST tiltable etalon saddled on the EQ-8.
Then sighted the sun.
My friend operated the focuser and the tiltable PST etalon.
I held the block filter unit (without PST ERF) on the 1-1 / 4 "nozzle with both hands.
I learned that Sahara dust is in the atmosphere, so I didn't see Venus in the daytime sky.
No H-Alpha in the sun, very dark sun through the dust .... but we both saw the Etalon-Donat, which tipped over the surface of the sun ..... so this the focus
..... i am Very Happy.
I will use the tiltable etalon on one refractor and the original etalon on the second.
Now I can take the measurements and take care of the adapters.
In the second photo you can see the focus when the block filter is attached.
sunny Greetings
Achim
sunny Greetings
Achim
- Solar-Cologne
I had a next Idea.....
I have already found an inexpensive adapter solution.
The lower PST socket under the BF 5 has an M33 x 0.75 thread.
The 1-1 / 4 "eyepiece holder has 31.8mm.
I will have it turned 5mm deep to 33mm and glue the lower PST socket there.
Now I need only 3 adapters .... but I currently have no more money .... broke.
First of all to mount the PST etalon on a 2 "focuser, as AOK-Swiss also offers. It is too expensive for me.
An adapter with an M50x1 internal thread and 2 "internal dimension to insert the etalon into the Matsumotos.
At least a adapter with rear T-2 external thread and front 2 "external dimension to mount the PST tiltable etalon on a 2" focuser.
Then I can finally pamper my eyes.
- Solar-Cologne
Well, progress is slow ... unfortunately, too slow.
My workshop for turning work, where Mathias Wirth / APM M.Ludes has his parts made, is fully booked.
I persuaded him tomorrow to at least quickly expand the two 2 "/ 1-1 / 4" reducers for the lower PST block filter nozzle to 33mm.
And it will be cost 10,-€....cool
So I can glue the two sockets there.
I can be very persistent when I have a goal in mind.
I try to keep the total costs under 4000, - €.
With two Baader 1.25x glass path correctors I can use 135mm aperture !
Sunny Greetings
Achim
Sunny Greetings
Achim
- Solar-Cologne
Yeah ... it's going ahead, faster than expected.
Peter Deuster, metal processing, Cologne, Widdersdorfer Str. 215
now makes me all 3 missing adapters by Friday noon, including PST etalon internal thread M 50x1 ...... insane, this adapter is nowhere to be bought.
Furthermore I have to widen my mauell fork assembly, at that time with Stefam Schimpf / Astromechanik in Volkach, for the 2 x 6 " Bino.
Originally there was a 2 x 120mm bino in there.
So I need the 2 horizontal aluminum plates new.
I went to Cologne, to "Wilms Metallhandel" .... Fa. sits next to Peter Deuster, and had the aluminum plates cut to me.
Then I saw 0.3mm red anodized aluminum material in a special offer in the sales room ... and had it cut to size for the two panels ...
Now glue on the red anodized sheets then drill the holes and the fork is ready.
See you on Friday.....
sunny greetings
Achim
The last photo shows the construction of the fork mount.
The picture is an advertising photo by Stefan Schimpf / Astromechanik in Volkach / Germany.
sunny greetings
Achim
Lovely!
- Has thanked: 17916 times
- Been thanked: 17060 times
Re: H-Alpha Double-Refractor 120 / 135 / 150mm Aperture ?
awesome looking refractors!!!
- Solar-Cologne
Today i tested one Refraktor for my Binoscope 120mm Aperture 6"f8 (H-Alpha f=10 ) with 135er C-ERF, PST-Etalon, Matsumoto EMS U-L, erecting Mirror System, PST BF 5mm a little bit tilted without the original ITF-Filter, Zeiss-Abbe Barlow with ClickLock 2,25 x and a Microskopocular WF 20x ( 12,5mm ).
It was a little cloudy in front of the sun, but still 216 x magnification ... wouw.
in the Bino 302 x !!!
You have to consider that when you look at real bino, our brain produces a 1.4 x larger image than monocular.
With Two Scopes....?.....400 x......500 x....we will see.
Do the test yourself with binoculars.
Alternately cover one of the lenses ....
- Solar-Cologne
I am currently widening the hand-guided fork mount by Stefan Schimpf / Astromechanik.
It was previously designed for a 2 x 120 FH bino.
My 2nd PST cannot be disassembled at the moment .......
The adhesive, similar to Locktite, sticks enormously.
sunny greetings
Achim
sunny greetings
Achim
Love it! I enjoy a bit of modding and building like that myself.
- Solar-Cologne
Me too ... because man / woman knows what you have.
The last adapter comes on Wednesday ..... waiting.
- Solar-Cologne
Still waiting ..... My metalworker only managed to make the adapters after Easter ..... a very lucrative order came in between.
- Rusted
- Has thanked: 8186 times
- Been thanked: 1943 times
Is there any difference between these specialist, bino diagonals and nested pairs of "normal" star diagonals?
- Solar-Cologne
What do You mean with "normal star diagonals" ?
The Mirror-System ?
Yes, a big difference.
The image is like a pair of binoculars, upright and sideways ..... very important for our brain.
The Mirror-System ?
- Rusted
Thanks. I saw these mentioned years ago on CN and by Dave Trott.Solar-Cologne wrote: ↑Fri Apr 10, 2020 8:59 am What do You mean with "normal star diagonals" ?
The Mirror-System ?
I believe they were described as "lazy diagonals."
A high degree of precision seems to be required.
If you have to ask the price you can't afford them.
- Solar-Cologne
Tatsuro Matsumoto in Japan builds very high precision.
It is not for nothing that Markus Ludes / APM and Matthias Wirth use often this EMS 60 ° two-mirror system.
https://www.cloudynights.com/topic/6654 ... 1200-bino/
https://www.apm-telescopes.de/de/ferngl ... o-152.html
http://www.astro-messe.de/AME2018/neuhe ... eiten.html
sunny Greetings
Achim
sunny Greetings
Achim
- Has thanked: 22 times
Now your talking this looks like a great quality rig Achim to
The PST BFs are actually 6mm it was only the very first ones from 04 that were 5mm.
I case you don't already know you may well have to apply some heat to your PSTs threadlock
with a good hairdryer to loosen it.
- Solar-Cologne
Hello Brian,
Nothing works with my hair dryer.
I'm looking for a hot air gun and big water pump pliers.
sunny Greetings
Achim
sunny Greetings
Achim
I like your styleSolar-Cologne wrote: ↑Sun May 03, 2020 6:57 pm I'm looking for a hot air gun and big water pump pliers.
Best of luck Achim ... I had a PST EP holder and spacer loosen in my hands this evening ,
the threadlock just fell to the floor .... and it is my original PST from 2005
- Solar-Cologne
Hello friends of the sun.
I went on vacation for several weeks in the German Eifel, near Laacher See.
After several attempts to solve the second PST etalon, I finally found a locksmith that has all the tools necessary to solve Locktite bonds.
The locksmith told me that we need at least 300 degrees Celsius for Locktite.
I got a little scared.
So we clamped the PST box in a large vice and I heated the etalon all around with a digitally adjustable hot air dryer.
We then took a pair of rough pliers and tried to loosen the etalon ..... no, no chance.
2nd attempt, warmed up again and tried with an approx. 80cm pipe wrench ..... finally the bond came off ....
Coronado....did a very good job.
My joy was very great, however, some mechanical traces were visible on the etalon, but it remained intact.
Now we have a cloud period here ..... laugh.
It is always the same before a "first light".
Now I have to attach the second C-ERF (160mm) in front of the second refractor and wait for our sun .....
Sunny Greetings
Achim
Sunny Greetings
Achim
- Solar-Cologne
Well, finally, adapt the 160 C-ERF to the 6 "lens.
It is an aluminum lightweight construction by Matthias Wirth.
I attached two small plastic washers to one of the retaining screws so that the ERF does not sit flat on the lens to avoid internal reflections.
Since the frame is a bit larger, I cut four spacers and fixed them in the frame by 90 °.
Then package tape had to be used again ...... laugh.
It works very well.
Now the Bino is complete and we are waiting .......for our lovely SUN.
It works very well.
Nice to hear things are developing with the project!
- Solar-Cologne
Hello Sun Friends.
The H-Alpha Bino is finally done.
The Bino won no beauty award .....
It works ......
but the look insight into all tested eyepieces is much too restless with the PST Blockingfilter and the Zeiss-Abbe Barlow.
It is not possible to observe with two eyes ..... too bad.
I am a little frustrated.
It works ......
Last edited by Solar-Cologne on Mon Jul 13, 2020 12:26 pm, edited 1 time in total.
- Solar-Cologne
I tested another variant on Sunday.
I temporarily installed my Lunt BF 1200 Blockingfilter on the left side.
Wouw .... the view is much calmer and you can directly see through the eyepiece without Barlow.
Now I have to save to buy a second Lunt BF 1200 Blockingfilter.
Or does someone of you have another Idea or a Tip for me ?
Sunny Greetings
Achim
Sunny Greetings
Achim
Looks good. Why won't it work with 2 eyes?
It looks really nice, Achim. I hope you can get it to work well. This should beat any binoviewer.
- Rusted
A fascinating project! Good luck in finishing it to your complete satisfaction.
I always use the B1200 for surface detail and the original PST BF5 for proms.
The difference is quite dramatic if I use the "wrong" BF for the wrong job.
The B1200 passes much less light than the PST BF.
Which demands lots of gain when minimum gain is desirable to avoid noise around proms.
On surface detail the contrast with the B1200 is far better than the PT BF.
There is quite a difference in power between my examples.
Which requires considerable refocusing.
