My fourth PST-Mod
Solar-Cologne
My fourth PST-Mod
Post by Solar-Cologne » Sun Nov 15, 2015 12:17 pm
Hello,
in 2012 at the ATT-Essen, the largest Astro Show in Germany, i became i unique item of an PST-Etalon in Aluminium case with mecanical Tuning and T-2 Adaptation. The original -200 and +200mm Telezentrik Lenses may be can removed.
Oliver was a little bit sad i became it first, it s a very nice Modification.
I use it with an Baader TZ-4 Telezentrics in my 6" Refractor with 120mm Aperture.
Setup here at the Picture is with the original Telecentrics.
This is my last Experiments with the PST-Etalon.
If you want more Resolution, you need an Refractor with more Aperture and an Front ERF.
The PST-Etalon makes automatically an f=10 System, if the focal ratio is lss then 10.
I cant use it in my Meade ED178, because the Tube is not shortend, i need the original one to use the Lille 50/50-System.
The Front ERF is the better Solution then an intern ERF.
If you need an intern ERF, like Lunt at Example, you have the Heat in the Tubus and Turbulence in it and the H-Alpha Quality is not so good like a front ERF, its cheaper ok.
In next Year i will test it with a modified Lunt60.....i have one of the best in the World from Markus Ludes/ APM-Telescopes / Germany.
sunny Greetings :D
Achim
Last edited by Solar-Cologne on Sun Nov 15, 2015 1:35 pm, edited 3 times in total.
Re: My fourth PST-Mod
Post by marktownley » Sun Nov 15, 2015 12:26 pm
Looks good! What are the views like through this visually?
Solar-Cologne
Post by Solar-Cologne » Sun Nov 15, 2015 12:38 pm
Hello Mark,
Thank you for your interest.
Its a little bit better like the original one, because there are less Reflexess and a homogeneously H-Alpha at the disk.
And with the Baader TZ-4 i have a f=40 System, its much better for watching H-Alpha.
Oliver uses sometimes f=50 and more....
sunny Greetings :D
Achim
