Quark mod into combo
DSobserver
Post by DSobserver » Wed Dec 09, 2015 1:18 pm
hello
Did anyone already looks how to mod a quark into combo?
Andover 656.3 Å 1 nm would most probably be needed, but how to remove telecentric?
Re: Quark mod into combo
Post by marktownley » Wed Dec 09, 2015 2:06 pm
The telecentric just unscrews off the back...
highfnum
Post by highfnum » Sun Dec 13, 2015 5:25 am
are you talking about that little ring that holds that reflective lens
or the whole black unit
Post by Valery » Sun Dec 13, 2015 6:19 am
Regular Quark will work like a Combo (or even better) if to use it with 0,5x reducer.
Post by marktownley » Sun Dec 13, 2015 6:37 am
Yeah, the whole black lens assembly just unscrews out of the quark body.
highfnum
Post by highfnum » Sun Dec 13, 2015 1:42 pm
"Regular Quark will work like a Combo (or even better) if to use it with 0,5x reducer."
Yes Valery I have tried this and it works well
but what would screwing off the lens assembly do for you? (its a different approach)
highfnum
Post by highfnum » Sun Dec 13, 2015 2:00 pm
Mark - still not precise enough
is the whole black part attached to the upper red part removed or
the inner 1.25 inch black stem?
Post by Valery » Mon Dec 14, 2015 1:14 am
highfnum wrote:Mark - still not precise enough
No! All what is before the red cylinder is removed. Only red cylinder and 1.25" visual back remain in use.
highfnum
Post by highfnum » Mon Dec 14, 2015 9:44 pm
thx Valery
Mark -- request was not to be a negative - its just me being very careful not to destroy item
but what would be advantage of doing this?
Post by marktownley » Mon Dec 14, 2015 10:03 pm
I know John, no worries ;)
DSobserver
Post by DSobserver » Mon Dec 14, 2015 11:23 pm
once more do we remove the black lens
or remove the black lens + add a 0.5 reducer
or add a 0.5 reducer in front of quark
If we talk about the 3rd option, I tried : picture of the sun is nice but full of dust and picture of kind of broken piece of glass. I mean there is superpositoin of a focus sun + focus dust fromthe quark...
