Which Quark for solar scope mod?
Post by Carbon60 » Wed Jan 06, 2016 8:35 pm
Reaching out to the experts.
Some of you may be familiar with my Lunt35 mod (150mm f10 objective, internal ERF, collimating lens, Lunt35).
Lens Configuration2.jpg (52.97 KiB) Viewed 1228 times
I'm considering double stacking using a regular Daystar Quark in the EP. My question is, would this work with my scope configuration since the Lunt 35 is an f11 scope and the regular Quark is optimised for f4-f8 scopes? The alternative would be the Combo Quark with my 2.5x Televue. In both cases I would probably use a 0.5x reducer to open out the field of view.
To date, I have been working with a second Lunt35 Etalon in DS mode, but getting an evenly illuminated field has proved really difficult. Would a DS Quark likely prove to be any better?
Thanks
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
Re: Which Quark for solar scope mod?
Post by marktownley » Thu Jan 07, 2016 6:45 am
You would end up with a massive focal length (6-7m?) with a regular quark. A quark combo would reduce this, but, remember quarks are not necessarily known for their evenly illuminated fields either. I think either would be a bit of a gamble trying personally.
I think the key to sorting this out is the mechanical tolerances and interfaces between the lunt units and the Istar scope. You got any pics of all this can have a look at?
Post by Carbon60 » Thu Jan 07, 2016 7:11 am
Hi Mark,
These were my concerns too and the reason for my extreme hesitancy. I have no experience with any of the Quarks and was aware of some of their idiosyncrasies wrt field uniformity and sensitivity to the light path. Mike G has had some success with various setups, though, which is why I was even considering this as an option.
I think you are right about the impact of tolerances, as sometimes the arrangement seems to work better than others. Maybe I should persevere with what I've got and save the £850!
I will post some images of the setup though.
Stu
NEQ6 Pro-mount
Derek Klepp
Post by Derek Klepp » Sat Jan 09, 2016 7:52 am
Stu Marks right about the Quarks .I have become frustrated with double-stacking due to this.
